It is currently Mon Aug 04, 2025 7:42 am
 Post subject: Bending purfling
PostPosted: Mon Apr 15, 2013 7:34 pm
I am planning to use a bwb, shell inlay, bwb purfling. i have the binding pieces bent and am going to use a teflon strip as a spacer for the shell. My question is do I have to pre-bend the bwb fiber strips? I seem to think so because they seem awfully stiff. These aren't individual strips, the bwb fibers strips are one piece. Will these bend on a bending iron? If soaking them will loosen them up how is the glue going to stick to them if they are wet? I plan on using Titebond to glue them in.
Thanks for any advice.
 Post subject: Re: Bending purfling
PostPosted: Mon Apr 15, 2013 7:40 pm
First name: Trevor
Last Name: Gore
City: Sydney
If you pre-bend them approximately to shape, you'll be fine. Do it on an iron, no water. Takes seconds. You can flex them from there. It's a big flex (and a handful to deal with) trying it unbent when you're laying in four pieces together.
http://www.goreguitars.com.au
PostPosted: Tue Apr 16, 2013 2:00 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
No you do not need to pre bend.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Tue Apr 16, 2013 6:06 am
agree no bending needed
PostPosted: Tue Apr 16, 2013 6:22 am
First name: Trevor
Last Name: Gore
City: Sydney
...until you read this bit of the puzzle. :mrgreen:
PostPosted: Tue Apr 16, 2013 7:27 am
First name: Tony
Last Name: C
City: Brooklyn
I have never had trouble bending the purfling on the top and back plates, regardless of what forum I posted on. I have had issues bending side purflings to shape without heat on an OM so now I bend the side purfling alonf with the binding, which is what most people seem to do.
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Apr 16, 2013 7:54 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Do you need to bend them? No. That said, I bend mine. Just makes things easier with fiber stuff. Plastic purf, not needed at all.
I either do it at the same time as the binding, or if something goes wrong (nah, that never happens) I do it on an iron. If using the bending machine with the binding, make sure not to go to tight. You are only doing this bend so not break things in tight areas, so not important to get the tightest bends.
PostPosted: Tue Apr 16, 2013 9:13 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I wet my purfling and tape it to the bending mold to give me an approximate shaping so I have no problems when installing. For rosettes I wet and wrap around a large can to get a close shape, I cracked a couple purflings before starting doing the cold bending.
Fred
Fred Tellier
PostPosted: Tue Apr 16, 2013 12:26 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I've seen purfling that had to be bent....the 1767 bwbw from stew mac (ukulele curves anyway)
Just bend it with heat. Watch out though...it can de-laminate so bend it just enough to flex it into position. If you have a problem rolling it when bending, I use a clothes iron on the bench to flatten it. It also helps to warm it up when fitting it onto the guitar
Users browsing this forum: DennisK, guitarjtb, Michaeldc and 13 guests
