It is currently Sun Jul 27, 2025 6:42 pm
PostPosted: Wed Apr 17, 2013 7:27 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Thinking of coming up with a new slotted headstock design for one of our guitars.
Are their required dimensions that I can access? Example - is there a minimum recommended distance between the slots? Is there a minimum width for the outer edges?
I'm guessing flat sides on the headstock are about the only way to go. No way to do curves - right?
Thanks for the help!
P A U L B U R N E R
Burner Guitars
PostPosted: Wed Apr 17, 2013 7:32 pm
http://www.stewmac.com/shop/Books,_plan ... _Plan.html
PostPosted: Wed Apr 17, 2013 7:37 pm
tuner dimensions and string clearance pretty much do it.
PostPosted: Wed Apr 17, 2013 7:39 pm
First name: Trevor
Last Name: Gore
City: Sydney
Check these out.
Make sure the strings clear the slot edges and wind straight on the shafts.
http://www.goreguitars.com.au
PostPosted: Wed Apr 17, 2013 10:59 pm
First name: Larry
Last Name: Hawes
Whoa Trevor, that was one incredible head stock.
The only thing I know is that the dimension along the outside of the head stock that the tuners go through (even in the wild design in the link above) wants to be consistent at around 1/4" but get your tuners first and try a couple dimensions to see what you tuners require. You want the dimension to allow the proper exposure of the peg hole to roughly center your strings in the slot - unless that is not required by your design.
I would have said yes till I saw that link above
Thank You and Best To All
PostPosted: Wed Apr 17, 2013 11:16 pm
The Sharpach archtop from the Chinery commissioned blue guitars had custom, curved, 3 on a plate tuners. http://www.scharpach.com/archtop-blue-vienna.php
PostPosted: Wed Apr 17, 2013 11:19 pm
First name: Trevor
Last Name: Gore
City: Sydney
Not mine, but I like the look. Not sure about the tuning stability, though, with the angled string take-off from the shaft.
The "standard" for classicals is 8mm (5/16"). You can go thinner, but you need to shorten the holding screws that go through the side plates. The flash ones with rolling bearings at both ends of the shaft may require some specific dimensions and close tolerances to get the best out of them. The screw hole spacings are never the same between makes, and its definitely smart to get the tuners before you build, particularly so you know that the head stock is thick enough and that any binding/purfling you have planned for the headstock will look right.
PostPosted: Thu Apr 18, 2013 2:39 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
You can also create the illusion of a curve! http://www.flickr.com/photos/matsudagui ... 4391918722 This one's by Matsuda.
Pablo Picasso
PostPosted: Thu Apr 18, 2013 9:12 am
Here is one of mine... I've done a couple of these and never had any tuning problem with it!
http://www.flickr.com/photos/xxl-guitar ... 4558746904
Users browsing this forum: Bing [Bot], rbuddy and 22 guests
