It is currently Sun Apr 19, 2026 8:22 pm
 Post subject: Steel String Rosettes
PostPosted: Wed Apr 17, 2013 11:54 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I'm about to start on a guitar which will be a replica more or less of an early 30's OM-18. This will be my first steel string type sound hole and I have a few questions. Where do I get purfling to match up with a 30's 18 style rosette (see pic)? Stew Mac or LMI don't seem to have the right combinations, unless I have overlooked something. Also, what is your preferred method of cutting the rosette channel? I am considering the fly-cutter type jig that LMI sells but it is expensive. Is it worth it? How about using a router? Or by hand via the Cumpiano method?
PostPosted: Wed Apr 17, 2013 12:13 pm
First name: jack
I believe you can probably get what you need from either Martin, or from John Hall @ Bluescreek guitars...The StewMac jig that utilizes a dremel style router works very well
For cutting the rosette channel a lot of us are using the Wells-Karol type jig with a laminate trimmer.
PostPosted: Wed Apr 17, 2013 3:30 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Thanks Steve and Jack. I will look into your advice. Im liking the Wells Karol jig. Seems much safer than a fly cutter on a drill press.
PostPosted: Thu Apr 18, 2013 12:16 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
A nice variation on the traditional Martin style rosette is to use end grained ivoroid and tortoise for the inner rings. +1 for the Wells Karol jig.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Thu Apr 18, 2013 12:21 pm
First name: Tony
Last Name: C
City: Brooklyn
If you like tiled rosettes, you can glue one up using thick tiles so that you can simply slice off rosettes as you need them. You don't need a lathe since you can use the circle cutter to cut out a rosette from your "blank" and vary the thickness of the rosette. Some could be narrow, others wider, but they will all look the same. I saw a guy do this over at luthierforum.com. I know the user was Steve Stevens, but I can't seem to find a link to the rosette. He made a tiled rosette about 2 inches thick, and sliced off rosettes as he needed them. He grew tired of the same design after a few uses though, so that's something to think about.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Apr 18, 2013 12:56 pm
First name: Larry
Last Name: Hawes
Found this thread Tony - I've been looking for something similar
http://www.luthierforum.com/index.php?/ ... e-designs/
Thank You and Best To All
PostPosted: Thu Apr 18, 2013 1:08 pm
The popsicle stick that Cumpiano shows works very well. For security I place a dab of superglue at the upperside base of the blade. Shellac the rosette area first. I use the small Stanley router Plane to cut the channel. The Veritas miniature router plane is on the shopping list. It's a pretty quick method and once you have set the inner/outer diameters it's there for future rosettes of the same.
PostPosted: Thu Apr 18, 2013 1:30 pm
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
That's a +1 for me on jackwilliams post. I am just starting an OM-28 thirties era and John Hall was very helpful with the rosette and purfling. The StewMac router jig works great for me as well.
PostPosted: Sat Apr 20, 2013 3:13 pm
First name: Tony
Last Name: C
City: Brooklyn
That's the thread!
PMoMC
Users browsing this forum: DennisK and 20 guests
