It is currently Sun Jul 27, 2025 6:42 am
 Post subject: Types of Guitar backs
PostPosted: Wed Apr 17, 2013 4:33 pm
First name: Tom
Last Name: West
State: Nova Scotia
Most folks will tell you there are two types of backs. One that is flexible and interactive with the top and one that is rigid and basically does not reinforce the top's output. Given the normal range of thicknesses of backs, I'm beginning to think there is only the interactive type. But they vary from quite supportive to not so much, but they all add something to the tops output. Wonder what other think, one way or the other?
Tom
PostPosted: Wed Apr 17, 2013 6:20 pm
First name: Trevor
Last Name: Gore
City: Sydney
To me, it's about whether there is a significant T(1,1)3 peak in the tap response spectrum. If there is, I class it as "live", if not, it isn't. Of course, the back doesn't "switch on" in a digital way, you can have more or less of it, as you choose. And there are higher modes of the back that contribute, too. But something like a Smallman style classical (~5mm laminated arched back) doesn't get close to what I'd be calling live.
http://www.goreguitars.com.au
PostPosted: Thu Apr 18, 2013 1:27 pm
First name: Tom
Last Name: West
State: Nova Scotia
Trevor: Are you saying a certain DB level on the read out, or a comparison between the levels of back and top?
Tom
PostPosted: Thu Apr 18, 2013 2:47 pm
First name: Jake
State: CO
Zip/Postal Code: 80129
Tom
Well, you can't say a certain dB on the tap response, because that will vary based on how hard you tap. Your tap may be much harder than Trevor's, and so even on the same guitar you will get different dB levels.
So you could compare the dB difference between the peak responses of first mode of the top and the first mode of the back. You might come up with a criteria, say, 10 dB. If the difference is greater, then the back plays a very small role.
Or perhaps an even better measure is whether you can even find the first mode of the back. It may be so low in amplitude that it is buried under the tails of other nearby modes, in which case it definitely doesn't play a significant role. Or it may occur at such a high frequency that it is lost in the sea of higher order top and air cavity modes. I think it is safe to say that if you can't even find the back response on your Fourier plot, then you probably can't hear it either.
PostPosted: Thu Apr 18, 2013 5:51 pm
First name: Trevor
Last Name: Gore
City: Sydney
Jake has pretty much covered it, referring to the size relationship between the T(1,1)2 and the T(1,1)3. There's more detail and specific criteria on p 2-40 and p 2-41 of the Design book. But definitely, if you can't identify a back response in the frequency response chart measured with a microphone, I doubt your ears can pick it.
PostPosted: Thu Apr 18, 2013 6:42 pm
there is a large variance of when the guitar is tapped in a free state and when it is tapped in a playing position. I am beginning to believe that it is more about air volume and how that is reacting with the top. I am not discounting the back but I think taping on a guitar if it is not in a playing position will give a false reading
just my 2cents
Users browsing this forum: ChuckB and 13 guests
