It is currently Sat Sep 20, 2025 12:09 pm
 Post subject: Top Joint Glue Up Mishap
PostPosted: Mon Apr 22, 2013 11:36 am
Last Name: Killin
I glued the redwood top plates together yesterday. Things actually went pretty well. I was able to plane the edge and get a good surface without needing to pull out the sandpaper on the level.
I used hide glue for the first time on this joint. That went well too. I used the tape method to clamp. I also stuck it in a Cumpiano style clamping jig.
My problem is, that I didn’t end up with a completely flat surface on either side. My alignment was off a bit. Its flat for a while then about 3\4 way through it shifts to the other side. There isn't that much that would need to come off to flatten it, but I’m wondering about the best way to separate this. Since I used hide glue I’m thinking I could just heat it with an iron to separate it. Then re-plane the surface and redo. Or I could bandsaw down the line and give it another go. Is the heat idea realistic, or am I kidding myself there?
PostPosted: Mon Apr 22, 2013 11:42 am
The only time I had that problem the plates were too close to final size and I needed to keep as much material as possible. I cut them apart with a little razor saw that has a 0.010" kerf.
Heat and a little moisture might work - I would use a damp cloth to separate the iron from the top.
Now I make sure I glue all of my tops together before thinning so I don't have to worry about minor misalignment.
PostPosted: Mon Apr 22, 2013 12:08 pm
That's what I'd do.
Alain Moisan
(Now building just for fun!)
PostPosted: Mon Apr 22, 2013 12:12 pm
First name: Larry
Last Name: Hawes
Alain Moisan wrote:
That's what I'd do.
SteveSmith wrote:
...Now I make sure I glue all of my tops together before thinning so I don't have to worry about minor misalignment.
Just had this happen with a center joint that was discolored. I squared it up then used the table saw to re-cut the joint, trimmed off the discoloration then re-glued and following Steve's advice, made sure all this was done BEFORE thicknessing the plates.
Thank You and Best To All
PostPosted: Mon Apr 22, 2013 1:21 pm
Last Name: Killin
I haven’t thicknessed the plates yet so I still have room for sanding. It isn’t that bad, it just isn’t right.
PostPosted: Mon Apr 22, 2013 1:53 pm
First name: Brad
City: St. Louis
It'll drive you nuts if you don't fix the alignment. Just use a small amount of water on a rag/paper towel to moisten the joint, and warm it up with a hair dryer or heat gun to separate the plates.
Brad
PostPosted: Mon Apr 22, 2013 2:10 pm
City: Tyler
If that's true, what diff does it make? It doesn't need to be perfect at this point. Accepting imperfection is a required trait in this craft, especially where it doesn't matter. IMO.
PostPosted: Mon Apr 22, 2013 2:47 pm
One of the reasons I thickness after gluing the plates is that I typically have an 0.010" to 0.020" mismatch between the plates. I just sand it out. If it gets much more than about 0.030" I would be looking at the method I use to join the plates.
PostPosted: Mon Apr 22, 2013 4:44 pm
First name: Hugh
Last Name: Evans
If its close enough that it will come out in the process of thicknessing, leave it alone. It you want to correct it you do have one option left before separating the joint. Apply a small amount of water along the line and let if soak in for a few minutes. Plug in an iron, turn it up to one of the highest settings but do not use steam. This will usually be sufficient to reactivate the glue. It will gel up normally after you remove the iron. Heat alone doesn't do the job with hide glue for long after assembly. I've seen it work with the right conditions a few hours after with veneering. A small amount of moisture wi give the proteins room to stretch out.
PostPosted: Mon Apr 22, 2013 5:29 pm
Another thing to consider is where the misalignment falls. If it will be in the soundhole cut out and under the fingerboard a slight misalignment is no big deal.
PostPosted: Mon Apr 22, 2013 5:36 pm
This is why I like LMI's Plate Joining Jig. Everything stays absolutely flat, so you can glue those thinner plates without issue.
FWIW, I wouldn't take the chance of being wrong about the thickness. I'd re-do the joint.
PostPosted: Mon Apr 22, 2013 6:01 pm
Last Name: Killin
Thanks for all the responses.
Right after work I went out and worked on it. My gut told me to redo it, but of course I didn’t listen. Well...... my gut originally told me to just sand it, and then I thought "No the right thing to do would be to redo it." Then I posted my question and went with the easiest solution.
I went ahead and sanded it and it worked out. I’m at 0.130. I probably could have gotten it thicker, but the belt slipped on the drum sander and I had to fix that. I wanted to be slightly thicker for when I worked on the rosette, but I should still be safe here.
If it had gone wrong, I’d be hosed. In hindsight, if I had to do this again, I’d probably redo the joint. It would have been the save move.
Thanks again.
Users browsing this forum: dofthesea and 22 guests
