It is currently Sun Apr 19, 2026 11:24 pm
 Post subject: Tuner height
PostPosted: Wed Apr 24, 2013 12:48 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
How high should steel string tuners extend above the headstock surface? I haven't got a 'standard' one to measure it from. Incidentally, what is the minimum thickness the headstock can be?
Pablo Picasso
 Post subject: Re: Tuner height
PostPosted: Wed Apr 24, 2013 1:20 pm
First name: Aaron
Last Name: Craig
State: Missouri
Go check out StewMac's tuners online and look at the specs for solid peghead tuners. There are nicely drawn diagrams that should help answer your questions.
Aaron Craig
PostPosted: Wed Apr 24, 2013 1:27 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Sorry, I should have phrased that better. I have the tuners and measurements for them, but the height is adjustable, depending on headstock thickness. To decide what thickness the headstock needs to be, I need to know how high they should stick out above it.
Pablo Picasso
PostPosted: Wed Apr 24, 2013 1:35 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
I think about 1/2 thick headstock is standard. But I guess it can vary. What tuners do u have? Don't make it too thin. On my first I made the headstock too thin and when I went to put the tuners on they bottomed out before they were tight. I had to modify them.
PostPosted: Wed Apr 24, 2013 1:41 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
OK, thanks. I have some wilkinson tuners with loose bushings, so there's no issue with running out of thread. 1/2'' would work fine.
Pablo Picasso
PostPosted: Wed Apr 24, 2013 2:10 pm
My plans say 16mm for the headstock thickness.
Sent from my KFTT using Tapatalk HD
Nick
Follow my musings on getting started in luthiery http://www.tredwellinstruments.co.uk
PostPosted: Wed Apr 24, 2013 11:34 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I make my pegheads 9/16" thick, which is the same as the 1930's Martins. That is 1/2", plus 1/16" for the peghead face veneer.
I generally use Waverlys (1.08" string posts), but a bit shorter is fine. For example, Gotoh Kluson Deluxe replicas are 0.965" and work fine.
PostPosted: Thu Apr 25, 2013 7:40 am
Actually, you're better to engage the upper nut sufficiently (1 to 2 turns?) and measure the resulting gap. Any headstock thicker than .600" and you might run into trouble (ie the top nut might not engage). Remember not all tuners are identical.
Milton, ON
PostPosted: Thu Apr 25, 2013 8:25 am
For me, 3/8" of the shaft extended above the face of the peghead is the minimum and 1/2" is the maximum. I taper my pegheads so both of these come into play with me. The minimum will have to take into consideration where this will leave the string hole in the shaft, as well as the width of the tapered area above and below the string hole. The bottom of the tapered area should be slightly above the face of the peghead.
James
PostPosted: Thu Apr 25, 2013 9:18 am
14-16mm seems to work for most tuners...
PostPosted: Thu Apr 25, 2013 11:03 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Thanks for the replies. I've thicknessed it to 15mm.
Now I just need to flatten the sides of the volute where I placed the tuners too far down and then plug and re-drill the tuner hole where the drill caught it. [headinwall] Ah, the joys of guitar building! laughing6-hehe
Pablo Picasso
