It is currently Sun Aug 03, 2025 1:01 pm
PostPosted: Mon Apr 29, 2013 10:02 pm
First name: Linus
City: Brooklyn
Zip/Postal Code: 11215
Hi Everyone;
I'm new to this and am working on my second build. I haven't yet invested in a pipe or bending machine.
It's a OOO build with white plastic binding and b/w fiber (0.025") side purfling. It seems pretty fragile and easy to break.
I've been reading through the previous posts using the search function but all instructions seem to indicate a need for a pipe or bending machine to bend the side purfling. Is there a way for me to soften this up without it? Will it work if I soak it in hot water for 5 mins? 15 mins? an hour? Or will the dyes run and will it just fall apart?
A bending machine or pipe is in my future but am I not ready to make that purchase yet.
Thanks much.
PostPosted: Tue Apr 30, 2013 1:20 am
First name: Dalton
Last Name: Courtney
City: Melbourne
State: Victoria
Zip/Postal Code: Australia
I have seen a blow dryer being used to soften the purfling. It is not the most accurate method for bending as you cant guarantee the heat will distribute evenly. Though with some care I have seen it come out successfully.
PostPosted: Tue Apr 30, 2013 1:54 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
You need a Bender....
Typhoon Guitars
PostPosted: Tue Apr 30, 2013 2:54 am
I bent my first set of sides and purfling using a blow torch and a metal tube. I doubt that it will cost $20 and if you beg or borrow it will be a whole lot less than that.
PostPosted: Tue Apr 30, 2013 4:56 am
Country: England
Kettle?
PostPosted: Tue Apr 30, 2013 6:15 am
BBQ Grill?
In a misguided attempt to multitask, I once bent bindings on the outer surface of a gas grill while cooking dinner. Bindings worked fine and it did an excellent job of ebonizing the steaks.
PostPosted: Tue Apr 30, 2013 6:29 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Build your own hot pipe with an electric charcoal starter in a pipe. It's cheap and works great. You could also try a clothes iron. I use it for flattening any jumps I get in my bindings before gluing then down. It does a pretty good job.
PostPosted: Tue Apr 30, 2013 7:10 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
old style makers of ouds bent the ribs over a candle.
This technology could be advanced by putting the candle inside a tin can.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Tue Apr 30, 2013 9:21 am
Last Name: A
curling iron should also work, I am sure you can get one a Goodwill for a couple of bucks or less.
PostPosted: Tue Apr 30, 2013 10:40 am
First name: David
Last Name: Morris
City: McKinney
I did this recently. It was a W/B/W binding, and it was terribly brittle. I soaked it in very hot water (too hot to touch) for about five minutes. It worked. I don't know how consistent the results would be, but it did at least work that one time.
I've also bent over the end of a clothes iron.
David Morris
PostPosted: Tue Apr 30, 2013 11:18 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Hi Linus - Did you buy the sides pre-bent? I assume so since you don't have a bending apparatus yet. You don't need much to set one up and can get all the stuff at the hardware store. All you need is: 2-3" diameter threaded black pipe, 10-12" or so in length, a screw on cap, a blow torch, and a shop vise. Drill a few holes in the end of the screw cap to let some of the heat breathe out. Hold the pipe in the shop vise and stick the blow torch in the uncapped end. Get a 1" pipe/cap for tight bends, if applicable.
PostPosted: Tue Apr 30, 2013 12:02 pm
First name: EddieLee
Last Name: Brown
I used a curling iron to touch up Binding and Purfling. Worked really well. Bigger diameter is probably better.
_____________
EddieLee
PostPosted: Tue Apr 30, 2013 12:20 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Steal your wife's steam iron, just don't get caught
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Tue Apr 30, 2013 12:48 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Clothes iron works well. And you can flatten it out if it rolls while bending. No starch please
PostPosted: Tue Apr 30, 2013 3:45 pm
First name: Linus
City: Brooklyn
Thanks guys!
I'm not worried about the plastic binding, just the fiber b/w 0.025" purfling.
I'll either make a pipe or get a curling iron from goodwill.
PostPosted: Wed May 01, 2013 2:09 am
I was binding a small oval sideport (2 x 3 cms) with 2 x 0.040" BWB fibre purfling (StewMac) and just passed it carefully over a boiling kettle and shaped it with my fingers.
It flops about almost like string.
I just put it back through the steam if it tightened up.
I had no issues with separation at all.
PostPosted: Wed May 01, 2013 8:41 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
An old hair curling iron will make a decent heat source to bend the purfling, just clean it well before putting it back and your wife will never know.
Fred
Fred Tellier
PostPosted: Wed May 01, 2013 2:41 pm
Last Name: Livermore
State: Minnesota
When bending purfling I cap a length of pipe, put the purfling in, then pour hot water into the pipe.
The purfling can then be bent easily into whatever shape you want it. Let it dry and it will stay in that form.
To do this with a guitar shape, I draw the outline of the side on a board and then tack the purfling in place along the line, placing tacks on either side of the purfling.
PostPosted: Sun May 05, 2013 5:13 pm
First name: Linus
City: Brooklyn
Well, a bending pipe will be necessary at some point so I might as well jump in.
I bought a 10" section of 1.5" pipe. Is galvanized OK? It's what they had. I got a propane torch. And they had a perforated rectangular plate. Tin? Almuninim? I'm not sure. I made a couple slices and bent it up to make a cone shape that I could jam into it to mostly plug the end while letting it breath.
I'll be able to lock it horizontally in a vice. Will this be OK??
PostPosted: Sun May 05, 2013 7:34 pm
State: Minnesota
Nice.
One little mod and you have a usable bemding pipe.
I cut the little tabs with a hacksaw, bent them with pliers or vice grips, dirlled holes and voila.
Many sets have been bent on this set up and you are almost there.
PostPosted: Mon May 06, 2013 12:59 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
How did you bend the sides on your first build? By the way I use an electric charcoal starter in a 2" steel pipe for my bending iron...Mike
PostPosted: Mon May 06, 2013 1:38 am
Last Name: Kincheloe
I think galvanized can produce toxic fumes when heated... not positive though, and perhaps not unless you get it hotter than it should be for side bending, but do look into it.
As for clamping in a vise, it'll probably work. My pipe is 3" diameter steel, free from a muffler shop scrap bin. Mounted to a board with L brackets and bolts, and then I clamp or screw the board to whatever surface I want.
Users browsing this forum: Darrel Friesen and 15 guests
