It is currently Sat Aug 09, 2025 1:05 pm
PostPosted: Mon May 06, 2013 1:39 am
First name: Sen
Last Name: Goh
Country: Singapore
Has anyone tried doing the side mass attachment (a la Trevor Gore)?
I am currently doing one and before I close the box I would like at least to get the side mass attached 1st if possible.
What would be a suitable material for the side mass?
I thought of using fishing weight but they are typically made of lead and considering the toxicity of the material, I don't really want to use it if possible.
Anyone has any good suggestions? Thanks!
Sen CL Goh
http://senguitar.blogspot.com
PostPosted: Mon May 06, 2013 2:30 am
I am using bright mild steel.
Are you pre-loading the sides before assembly? How do you know how much to use?
My understanding is that side mass is used to lower (trim) the top resonance after the box is assembled, and testing the coupled top, body and back frequencies.
PostPosted: Mon May 06, 2013 5:55 am
First name: Trevor
Last Name: Gore
City: Sydney
Correct.
Anything dense works. Steel, brass, silver, gold, depleted uranium (if you like exotic-toxic)...
http://www.goreguitars.com.au
PostPosted: Mon May 06, 2013 8:55 am
First name: Sen
Last Name: Goh
Country: Singapore
Thanks Colin and Trevor for the suggestion.
Well I just wanna make sure I am able to install it via the sound hole before I close the box.
Sen CL Goh
PostPosted: Mon May 06, 2013 5:28 pm
Don't worry about fitting it through the soundhole, just glue it to the outside. Call it - Mass, externally, surfacially secured (M.E.S.S.) and sell it as a feature. Isn't that what the best luthiers do?
Trevor,
Will D.U. give ones guitars that penetrating sound?
PostPosted: Mon May 06, 2013 5:45 pm
First name: Trevor
Last Name: Gore
City: Sydney
Clay S. wrote:
Trevor,
Will certainly increase the projection.
PostPosted: Tue May 07, 2013 5:43 am
First name: Tony
Last Name: C
City: Brooklyn
Trevor Gore wrote:
Correct.
I wouldn't use depleted uranium. It's almost as hard to export as Brazilian rosewood.
http://www.CostaGuitars.com
PMoMC
Users browsing this forum: Bing [Bot], Patrick B Wilson and 37 guests
