It is currently Thu Aug 14, 2025 1:28 am
 Post subject: Bridge slot problems
PostPosted: Tue May 07, 2013 2:52 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
I was cutting a slot for the saddle with a Bosch Colt, and the bit got pulled into the slot. It was well tightened and I was taking light passes. The wrong kind of end mill? Upcut? Downcut?
Any thoughts would be appreciated.
Thanks in advance.
 Post subject: Re: Bridge slot problems
PostPosted: Tue May 07, 2013 3:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
When you seat the bit in the collet, back it out 2mm so that it isn't bottomed out. A bottomed bit will not tighten well, on occasion. If there is any glazing on the shaft of the bit, clean it with blade cleaner.
Alex
PostPosted: Wed May 08, 2013 8:53 am
First name: Tony
Last Name: C
City: Brooklyn
Did the bit get pulled down into the slot, making your slot too deep, or did it catch on the side of the slot and take out a divot on the side? If option 1, Alex is correct. Don't bottom the bit in the collet. If option 2, then, umm...hold on tighter!
http://www.CostaGuitars.com
PMoMC
Users browsing this forum: Durero and 27 guests
