It is currently Thu Aug 14, 2025 11:25 am
PostPosted: Tue May 07, 2013 4:32 pm
Last Name: A
Hello - I bent Honduran Rosewood successfully on my form, no cracks or warping. But I do have a good amount of spring back. Ideally I want this to slip into my mold without too much spring back.
1. If I place this back on my mold - any ideas if this is good and how long should I put it in for ?
2. Should I cut my form back a little to overcompensate for the spring back ?
I tried correcting the spring back on the pipe - but for some reason this wood is very resistant to bending on the pipe.
PostPosted: Tue May 07, 2013 6:35 pm
I'd put it back in the bender slightly wetted again and cook it at 320-350 for another ten minutes and see what happened....
PostPosted: Tue May 07, 2013 7:49 pm
you should have a slight about of compensation designed into your pattern. At 350 for 5 minutes you will get a good bit of resin.
PostPosted: Tue May 07, 2013 9:16 pm
Last Name: A
Thanks John - I just trimmed my form a bit and cooked 230 degrees for 45 minutes - I think that will do the trick - will confirm in the morning.
PostPosted: Wed May 08, 2013 3:01 pm
Last Name: Sollod
...I think you can over-cook the side and the wood can become brittle and cracking can occur. At least I seem to have had that happen to a black limba side...
www.swiftcreekguitars.com
PostPosted: Wed May 08, 2013 6:45 pm
Last Name: A
there's always something - recooking it seemed to have worked - I added more water to keep from over cooking it - we will see how she holds up in the future !
Thnks for the help
Users browsing this forum: Gary Davis and 42 guests
cron
