It is currently Fri Aug 22, 2025 5:24 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 16, 2013 6:31 pm
First name: Jim
Last Name: Kirby
I always thought the 49 was too course to do anything with - always went to the 50 right away. My largest Auriou is a 10, with a cutting surface length about an inch shorter than a 49 or 50, and I'd guess the tooth size is about 1/2 of the tooth size on a 50.
I use that for the heaviest work of neck shaping.
Jim Kirby
kirby@udel.edu
PostPosted: Thu May 16, 2013 7:01 pm
I can't add to what the rest have said regarding the better rasps except for this;
I use a cheap $8 rasp to carve my necks, and it works well for me.
However, I have enough experience in metal work using files to know that the better ones are well worth it. If I can ever afford to I'll upgrade, and I don't think you'll ever regret doing so as well.
