It is currently Tue Aug 19, 2025 3:37 am
 Post subject: Nitro spray on glasses
PostPosted: Fri May 17, 2013 11:25 am
First name: Alain
Last Name: Gagnon
City: Ottawa
State: ON
Usually I don't wear my glasses when spraying. I use rattle can watco. Anyway I got spray dots on my glasses. This must have happened to someone out there before. I could scrape with a razor blade or use lacquer thinner. Any other suggestions.
Alain
_______
PostPosted: Fri May 17, 2013 11:46 am
Sand level and buff laughing6-hehe
oops_sign Actually I would suggest trying the solvent first!!
PostPosted: Fri May 17, 2013 12:53 pm
I always used thinner.
PostPosted: Fri May 17, 2013 12:58 pm
First name: D
Last Name: S
Be carefull around the edges so you don't sand through.
Sorry, are they glass or polycarbonite?
The only safe cleaner for polycarbonite that I found (on the web) that I could pronounce was kerosene.
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri May 17, 2013 1:01 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I used methyl hydrate to clean nitro off of my glasses a few years ago.
Alex
PostPosted: Fri May 17, 2013 4:15 pm
First name: Stuart
Last Name: Gort
If they are glass just use acetone.
StuMusic
PostPosted: Sat May 18, 2013 4:25 am
Test in an inconspicuous area first....
PostPosted: Sat May 18, 2013 12:29 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Two words... GLASS LENSES! I have ruined plastic lenses in less than a week after being talked into buying them. Never again. In my experience, strong solvents will damage most plastic lenses.
PostPosted: Sat May 18, 2013 1:32 pm
First name: duh
Last Name: Padma
You might be surprised what soaking for a day or to in just water and vinegar will do.
If that don't get the pig clean, then up the anti to the mild, low volatility petroleum distillates commonly called Mineral Spirits or White Spirit off continent.
If that don't work...go here http://www.eyebuydirect.com/ Prescription glasses cheap like borscht.
blessings
