It is currently Fri Aug 08, 2025 3:02 pm
PostPosted: Mon May 20, 2013 10:03 am
Chris, there is a good sharpener here in Charlotte. Charlotte Saw and Knife. Reasonable pricing and excellent work. They do router bits, saw and bandsaw blades (longer than 80" only, I think) and hand tool blades. Not high tech but an operation that's been in business for over 80 years. Never asked them about fret saw blades, but I don't see why not if you give them the specs. The guy that runs the place is a Gibson collector. Loves guitars.
http://charlottesaw.com
Their website says if you have custom needs they will try to accommodate.
PostPosted: Mon May 20, 2013 11:50 am
Circular saw blades are pretty easy to sharpen yourself using a triangular file.
PostPosted: Mon May 20, 2013 12:07 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have had mine resharpened at a local saw shop. The Stew Mac blades are hollow ground, rather than having set teeth. Even so, I think you would really have to cut a lot off to significantly reduce the kerf.
PostPosted: Mon May 20, 2013 6:20 pm
please do a test run with any person/business you choose to sharpen a blade...the last time I had a blade sharpened they:
1) used one of those vibrating etchers to etch the company name into the plate (it warped the plate a tad)
2) did NOT follow the original tooth configuration from Freud (an LU-85) and took off way too much material because of that
3) burned the teeth
4) wasn't a very good sharpening job and didn't last for any real period of time...
basically they ruined the blade...
PostPosted: Mon May 20, 2013 6:51 pm
State: Tennessee
3) burned the teeth
My dad and brothers have largish cabinet/custom furniture shops and have had varying degrees of success with local sharpening. Forrest saw blades offer saw sharpening and they have used them for years now with great results. I'm talking sending a dozen blades off at one time. Our local woodcraft has a guy in Oak Ridge I tried and my blade came back actually better than new.
PostPosted: Mon May 20, 2013 10:22 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I sharpened some fret saw blades (the hand held one, not the tablesaw blade) with a dremel grinding wheel... same way you would sharpen a bandsaw blade.
Typhoon Guitars
PostPosted: Tue May 21, 2013 4:27 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I use Forrest as well and highly recommend their sharpening service. As for fret saws, this is one reason I use a handsaw. I can sharpen it any time I need in about 5-10 minutes.
Brian
Users browsing this forum: Bing [Bot] and 23 guests
