It is currently Sat Jul 26, 2025 3:15 am
 Post subject: Side ripple/fold
PostPosted: Tue May 28, 2013 9:03 am
My current builds of cocobolo and ovangkol has some side ripple as you can see from the pics after I drew a soapstone straightedge around the sides. Obviously the visible soapstone rubbings show high spots. Mostly these are very small ripples and I canscrape them flat. However, I want to avoid these problems in future builds. Wondering whether I used too much moisture in bending or too much gobar pressure when gluing on back and sides. Any suggestions would be welcome. Thanks.
Sent from my GT-P3113 using Tapatalk 4 Beta
Under Compensated Nut!
 Post subject: Re: Side ripple/fold
PostPosted: Tue May 28, 2013 9:56 am
how are you bending your sides. machine? iron? other?
PostPosted: Tue May 28, 2013 10:05 am
I'm using a fox bender with a heating blanket. I don't have a temperature monitor , just a controller. So amount of heat might be an issue?
PostPosted: Tue May 28, 2013 10:09 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
How much water. I don't think you used excessive heat as the coco will darken quite a bit and give off a lot of burned black sap if over heated. I just dampen the coco a bit before bending. I have never bent ovangkol so don't know about it.
Fred
Fred Tellier
PostPosted: Tue May 28, 2013 11:26 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I always expect some "rippling" in the sides after bending. Some of it may disappear after a few days in the mold, but the rest will need to be sanded out. Lay a straightedge across the high spots to see how much material will need to be removed. Depending on how thick the sides are & how high the humps, you should be able to block sand the sides smooth.
I have been using Supersoft II for quite a while now... Much better results than with water.
PostPosted: Tue May 28, 2013 12:14 pm
I had ripples before finding a way to add tension to the bending process. Adding the tension essentially eliminated them.
I bend the waist first, but not all the way; I'll leave it so it's 1/2" or so from the form. Lower bout, upper bout, then finish the waist by setting it all the way. It pulls everything tight to the form.
I think I read about this method first from Lance, and then from Todd's bending videos on YouTube. Works like a charm. No ripples.
PostPosted: Tue May 28, 2013 1:48 pm
Thanks guys. James, that's the method I have used as well. I am using solid mold, but it is not the full width od the sides. Four pieces of 3/4 ply laminated together.
PostPosted: Tue May 28, 2013 2:14 pm
from what i can see is that you need better support. make a full width body insert for your fox. use a slat between the blanket and the wood and use springs to pull it down the sides of the upper and lower bouts. i put in about 3 to 5 degrees of draft on the bout ends to adjust for springback as well.
