It is currently Wed Jul 23, 2025 7:48 pm
PostPosted: Mon May 27, 2013 2:42 pm
As some may know I live on a caribbean Island and importing cans of chemicals is not an option for me.
I have found a local paintstore that sells Watco clear wood finish as a brush on Lacquer. After some research it appears that this is in fact Nitro and Im wondering if spraying it might be possible?
PostPosted: Mon May 27, 2013 5:42 pm
If I'm correct (and that's a big if), brushing lacquers basically are thinned out versions of lacquer, or in some other way treated so that the lacquer will flow out better, so that the brush strokes will disappear. I think they also have more retarder in them to give the lacquer a longer cure time to also aid in this.
I don't see why you couldn't spray it. I'd try it on some scrap and see. MHO.
PostPosted: Mon May 27, 2013 6:49 pm
First name: Tony
Last Name: C
City: Brooklyn
Deft sells their lacquer as a brushing lacquer because of some regulations that make it more expensive or difficult to sell it as a spray version. But, you can thin it and spray as a friend confirmed through the company. I bet this stuff is the same.
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon May 27, 2013 8:07 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I have sprayed Deft brushing lacquer with no problems. Took a little longer to flash of, is all.
This was a long time ago & I don't have any notes on how much I thinned the stuff, but I remember it being very forgiving.
I did find that Deft took a long time to harden up & even after months, it was noticeably softer & more easily scratched that the Mohawk lacquer I use now.
PostPosted: Mon May 27, 2013 8:19 pm
Yes, you can spray Watco lacquer. Thin it just enough to get it through your gun and lay out nicely. I do about 15% by volume. Give it plenty of cure time, six weeks is good. Watco doesn't have the same plasticizers (flex agents?) as instrument lacquer so keep the finish thin or it might (will) crack.
PostPosted: Tue May 28, 2013 5:30 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Yes I have done it. Add thinner until it will spray. But be aware, This practice is completely illegal as far as the EPA is concerned and could get you far more than you bargained for depending on where you live and if they decide to make an example of someone.
It will remain softer than most other spray lacquers. Deft is the worst...even the rattle can stuff stays very soft for many months.
Brian
PostPosted: Tue May 28, 2013 6:37 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
B. Howard wrote:
. But be aware, This practice is completely illegal as far as the EPA is concerned and could get you far more than you bargained for depending on where you live and if they decide to make an example of someone..
Really?!? What a bunch of crap. Ugh, the EPA just really gets under my skin
PostPosted: Tue May 28, 2013 7:34 am
Being in the Caribbean, I don't think Steve needs to worry about the EPA.
Jim Womack
Will Rogers
PostPosted: Tue May 28, 2013 8:07 am
Thanks for the replies..Im going to get some and try it.
I was wondering why there was no spraying version of the product.
You are right Jim. If the E.P.A. came down here spray Lacquer would be the least of their worries
Their heads would probably spin right off!
PostPosted: Tue May 28, 2013 8:47 am
First name: Al
Last Name: Darned
Many finishes are sold thick with warnings on the labels not to thin. This is not because thinning is not something you might want to do to improve application or because it will somehow harm the end product, but because it will increase the solvent to solid ratio, running it then afoul of the regulations ... were it not for the regulations you could thin pretty much anything with the appropriate solvent to get the application characteristics you prefer, and the end result would be just fine;)
If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason. - Jack Handey
PostPosted: Tue May 28, 2013 4:54 pm
If you could add some plasticizers you could improve its resistance to crazing and weather checking, but being in the caribbean this might not be a problem.
Users browsing this forum: doncaparker and 30 guests
