It is currently Sun Aug 17, 2025 3:26 am
 Post subject: 630 scale
PostPosted: Mon Jun 03, 2013 11:12 am
Hey guys hope you all are well! In your expert opinion what is the best bridge placement on a 630mm scale classical guitar? This is what i have...51mm @ nut,61mm @ 12th fret, 315mm leingth @ 12th fret, 419.8mm @ 19th fret, 2.5mm radius @lower bout, 2mm angle on neck from 19th fret. I look forward to your reply!! Thank you
 Post subject: Re: 630 scale
PostPosted: Mon Jun 03, 2013 4:08 pm
Well, I'm not sure I understand your question. To me the answer is pretty straightfoward: so that the saddle will lay at 632mm from the nut. If your neck joint is at the 12th fret, you don't have much choice.
Alain Moisan
(Now building just for fun!)
PostPosted: Mon Jun 03, 2013 8:12 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
What Alain said. Compared to a 650mm scale neck, the neck is shortened 1 cm, and the bridge will need to be moved 1 cm. Check your fan/brace placement to ensure that the outer end of the bridge covers what it needs to.
http://redrivercanoe.ca/
