It is currently Tue Aug 19, 2025 10:04 am
PostPosted: Fri Aug 02, 2013 1:29 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
Not a riddle folks but the subject of my latest blog post. Take a look, I'd be interested to hear your take on the subject - what you've learned over the years.
http://www.nkforsterguitars.com/blog/fl ... inder-top/
nigel
http://www.theluthierblog.com
PostPosted: Fri Aug 02, 2013 5:27 am
99% of guitars before 1850 had true flat tops. Their was a maker sometime in the early part of the 19 th century who was making Guitars similar to your cylinder model.
Not a lot new under the sun, as they say.
PostPosted: Fri Aug 02, 2013 8:49 am
First name: Tom
Last Name: West
State: Nova Scotia
Nigel: Interesting, must really raise the longitudinal stiffness. Wonder if the radius is even or just centered with the sides of the top flatter. Also, what is the radius your using? And the effect on overall sound ? Had considered doing this to the back of guitars but have not gotten there yet.
Tom
PostPosted: Fri Aug 02, 2013 9:36 am
First name: George
City: Seattle
I don't have any experience with this myself, but I believe that Laurent Brondel builds with laterally arched tops and backs and I don't think he does anything without careful thought and analysis. It's been a while since I've seen him post. Maybe this thread will lure him back in.
You are a daring man with that chisel, Nigel. I'd surely slip and leave a terrible gouge in the side. :-)
George :-)
PostPosted: Fri Aug 02, 2013 10:51 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So is there a reason why many luthiers carve the neck already attached to the guitar? It seems easier to carve it without the body in the way, and no risk of damaging the body too...
Typhoon Guitars
PostPosted: Fri Aug 02, 2013 11:13 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I've done one or two that way, I use a different geometry now. I didn't change because it didn't work, it just doesn't fit in to my (ever-evolving) building procedures as well as my new geometry. Basically flat to the bottom of the soundhole, 15' radius dome below the soundhole.
PostPosted: Fri Aug 02, 2013 12:27 pm
First name: nigel
Last Name: forster
Country: england
Quite a few points to answer there:
"99% of guitars before 1850 had true flat tops. Their was a maker sometime in the early part of the 19 th century who was making Guitars similar to your cylinder model.
Not a lot new under the sun, as they say."
Michael:Very true. and before 1850, I think most guitars had gut strings. So it's interesting to see the various responses makers had back then to steel strings when they became available for guitars. (When/how did that happen exactly?) The response that "took off" as we all know was the spruce x brace, but it wasn't the only one. My feeling is the cylindrical arch Howe Orme response to the structural problems is one worthy of investigation, and development. That's why I've been working with it the last few years.
Tom:"Wonder if the radius is even or just centered with the sides of the top flatter. Also, what is the radius your using? And the effect on overall sound ?"
I've no idea of what radius I'm using.
This should give you an idea -
And how does it sound? -
http://www.youtube.com/watch?v=N0zz4Pu8wyU
Tai:"So is there a reason why many luthiers carve the neck already attached to the guitar?"
No! In that case I was trimming the heel flush to the sides whilst it was just bolted in place. That said, I've carved necks both on and off the guitar, off is a little easier, but I've never slipped with a chisel once whilst carving a neck. It helps to concentrate the mind when the stakes are high!
I've written quite a bit on my blog over the years about the Howe Orme design, if you spend a bit of time there, you might get a few more answers - there are plenty of pictures.
nigel
PostPosted: Fri Aug 02, 2013 6:56 pm
First name: tim
Last Name: minkkinen
City: charlotte
State: nC
Zip/Postal Code: 28203
Country: united States
Study the Larson bros. Maurer. Prairie State. The cylindrical top has been around and made en masse. A proven great idea. T
PostPosted: Fri Aug 02, 2013 9:28 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I've always had issue when doing a uniform radius on the top that there's always a gap under the fingerboard at the neck/body joint. If I changed the angle to eliminate that gap the angle is too high. So I'm contemplating a true flat top but radius the X braces so the body still gets into an arch of some kind but not at the upper bout.
Typhoon Guitars
PostPosted: Fri Aug 02, 2013 10:48 pm
First name: Lincoln
Last Name: Goertzen
City: Fort St John
State: BC
If I understand you correctly, Tai, you are thinking about it backwards. You would be better off to radius only the upper transverse brace, and leave the X alone, like Santa Cruz did when they started out (I'm not sure if they still do it that way.)
Have you watched John Hall's youtube videos? He shows his method of achieving the correct geometry, which is easy and effective.
PostPosted: Fri Aug 02, 2013 11:00 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I can't find the video you're talking about. I really like to know this because I find it hard to deal with that gap and really want to eliminate it. I just don't know about sanding the bottom of the fingerboard because it always ends up coming out weird...
Typhoon Guitars
PostPosted: Sat Aug 03, 2013 12:40 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I thought of the Larson Brothers when I read his blog. I believe the reason methods like this didn't last is because it's a lot more difficult in a factory setting. Factory guitars were built pretty much by average people who were trained in specific operations.
PostPosted: Sat Aug 03, 2013 1:58 am
First name: nigel
Last Name: forster
Country: england
FishtownMike wrote:
I thought of the Larson Brothers when I read his blog. I believe the reason methods like this didn't last is because it's a lot more difficult in a factory setting. Factory guitars were built pretty much by average people who were trained in specific operations.[/quote
Great minds think alike chaps! The design here combines several ideas - the Howe Orme cylindrical arch, Larson inspired spruce and rosewood laminated braces, and my own X brace.
Tai: my cylinder tops have a fixed neck and getting the geometry right is really tricky, but it's doable.
but Howe-Orme (the original cylinder top guitars) got around the problem by having a floating adjustable neck. Theirs is a very pragmatic design.
How many of you experiment with soundboard shape beyond spherical formers? Can you imagine what the advantages of this might be? What puts you off?
nigel
PostPosted: Sat Aug 03, 2013 5:21 am
Cylinder guitar (or at least heavily arched) both Top and Back:
http://www.sinier-de-ridder.com/guitare ... r-eng.html
Obviously built for Gut. There are earlier examples of this type. 1840 was near the peak of interest in the 6 string Guitar, being at or near the time when Sor, Carcassi and Giuliani were plying their trade. The switch to 6 single strings coincided with a popular surge of interest in the Guitar, hence the number of composers writing for the Guitar increased and there were a huge number of attempts to 'improve' the instrument. Some of these attempts were very weird and wonderful.
These users thanked the author Michael.N. for the post: Jimmyjames (Sun Apr 05, 2015 12:14 am)
PostPosted: Sat Aug 03, 2013 3:16 pm
First name: nigel
Last Name: forster
Country: england
Great looking guitar - the side view is very similar to one of my standard guitars or a Sobell where the sides are fitted to the ribs and not pulled at all.
nigel
