It is currently Wed Aug 20, 2025 6:53 pm
 Post subject: fret end beveling
PostPosted: Sun Aug 04, 2013 12:16 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Does anyone here find the Stewmac tool for beveling fret ends necessary? I use a large file to bevel the fret ends but the problem is the file is awkward to handle, and if I am not careful I can damage the guitar. I want to cut the file and mount it in a wooden jig but the problem is, I do not have a tablesaw so I can't really make the proper angled cut... only have a bandsaw.
Also I found the file isn't flat, and I suspect most files aren't flat unless they're precision ground flat and then toothed... so what works?? The Stewmac version is almost 50 dollars...
Typhoon Guitars
 Post subject: Re: fret end beveling
PostPosted: Sun Aug 04, 2013 12:50 pm
I use the StewMac fret beveler whenever I do fret work, precisely because using a long file to perform that job is awkward - especially on set necked instruments.
As for files.... they do sometimes warp in the heat treating process, despite starting out flat. All you can do is check them before you buy them.
PostPosted: Sun Aug 04, 2013 1:03 pm
First name: William
Last Name: Snyder
City: Brooklyn
Why can't you cut the proper angle? Handsaw is pretty quick and easy. If you need a guide to get the proper angle by hand then you could plane the angle onto the edge of a scrap piece to use as a guide.
Or you could use your band saw. Just cut the piece of wood all the way through at your desired angle then glue in a partial-depth spacer that is the same thickness as your file.
PostPosted: Sun Aug 04, 2013 1:39 pm
+1.
That's the way I did mine, on the bandsaw - 6 inch Faithfull brand file (check reasonably flat before you buy), knock off the tang, grind the rough bit, epoxy.
PostPosted: Sun Aug 04, 2013 6:06 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
How do I cut a file? Hacksaws won't touch them...
Typhoon Guitars
PostPosted: Sun Aug 04, 2013 6:14 pm
Abrasive cut-off wheel. Do you have a Dremel kit?
PostPosted: Sun Aug 04, 2013 6:19 pm
City: winnipeg
State: manitoba
Country: canada
I use a chop-saw with a friction cut-off wheel. You can get an abrasive blade for a normal skil-saw.
Bob :ugeek:
PostPosted: Sun Aug 04, 2013 6:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have a dremel type tool and cut off wheel, but I am afraid of using them on a file... it's a little too big for that. I might see to go and see if there's anyone with abrasive chop saws that I can borrow for a few minutes...
Typhoon Guitars
PostPosted: Sun Aug 04, 2013 7:20 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
It would be a lot easier to take the file to the chop saw! :)
Alex
PostPosted: Sun Aug 04, 2013 7:26 pm
First name: anthony
Last Name: wickman
City: tallahassee
State: florida
Zip/Postal Code: 32301
All you have to do is score the file then put it in a vise and hit it with a hammer. It will snap along the scored line. I use a grinder to score a line.
PostPosted: Mon Aug 05, 2013 1:32 am
First name: duh
Last Name: Padma
An old sanding belt on the belt sander and me fret ends are beveled in under 60 seconds...way faster and cheaper than any file...even if its a StewMac file. laughing6-hehe
PostPosted: Mon Aug 05, 2013 9:48 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
What do you do when you are over the body? it gets really easy to damage the body when you need to dress the end there...
Typhoon Guitars
PostPosted: Mon Aug 05, 2013 10:36 am
I use the StewMac file as well but have found that metal filings can get between the plastic block and frets and ding up the tops. I usually tape off the tops except for the edges so the block rides on the tape to prevent that.
Users browsing this forum: doncaparker and 19 guests
