It is currently Mon Aug 18, 2025 6:10 am
PostPosted: Tue Aug 20, 2013 11:22 am
First name: Blake
Last Name: Dixon
City: Kelowna
Zip/Postal Code: V1V1W7
Brace wood the lighter is better or what?
Is Engelmann good for or as brace wood, I have access to a large amount of Engelmann for brace wood. The only thing is this wood, the grain is a little wider than I usually use. I am building Nylon string 14 fret cross overs. My own design. Any advice would be appreciated. This wood is rather light in weight yet fairly strong in the deflection tests I have done
In engineering terms, the deflection varies as the inverse of the cube of the depth, so if we increased the test sample from 1/2" deep to 9/16" deep (only a 12.5%
Increase) the deflection should be nearly half, decreasing from 23mm to 12mm (calculated as 23/1.25x1.25x1.25). To check this, you could cut a piece 9/16" in grain direction x 1/2" x 20" long and hang the standard brick on it. A 12.5% increase in volume would increase the brace weight the same as increasing the specific gravity from 0.34 to 0.38 (calculated as 0.34x1.125). The end result is this new brace (but deeper) would be very nearly the same stiffness and weight as one from your local lumberyard englemann spruce. In fact, it would be quite a bit lighter brace than the Sitka brace I used in the past.
I thought this would make a great discussion for the forum.
Blake.
Blake Dixon
Kelowna B.C.
PostPosted: Tue Aug 20, 2013 2:32 pm
Last Name: Cox
For a nylon string - I would want Light bracing anyway.... We aren't talking "Framing lumber" like on big body Steel strings....
Then.. Wide vs Narrow grain... Doesn't really correlate to anything useful structurally.... and it's going to be in the braces up under the soundboard anyway....
So why not go ahead and use it for bracing.
PostPosted: Wed Aug 21, 2013 12:21 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
What truckjohn said!
You can ship some of that this way !
I'd gladly pay you for some!
Mike Collins
PostPosted: Wed Aug 21, 2013 12:39 pm
First name: Ringo
With spruce, stiffness tracks density in a linear fashion and it's usually very consistent across species, so that lighter spruce (like Englemann) is less stiff and heavier spruce (like red) is more stiff. If a piece of Englemann is 20% lighter, it will usually be about 20% less stiff at the same thickness. Number of grain lines per inch doesn't seem to matter... weight is a much better indicator. Keep in mind that grain runout will lessen stiffness too, so if your local lumberyard Englemann has a lot of runout it may not be ideal.
Taking measurements of weight and deflection with the wood you have is the best way to figure out which wood will work best for your design. You can use those measurements to get the maximum stiffness with minimal weight.
PostPosted: Wed Aug 21, 2013 1:00 pm
First name: Blake
Last Name: Dixon
City: Kelowna
Thanks so much
Blake
Blake Dixon
Kelowna B.C.
PostPosted: Wed Aug 21, 2013 1:13 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
You also might also want to delegate the engl. spruce into 3 piles, light , med, and hard depending on their densities an future application.
PostPosted: Wed Aug 21, 2013 7:06 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
If a piece of Engelmann is 20% lighter, it will usually be about 20% less stiff at the same thickness.
True, but because of the cube rule and the fact that braces can vary in height, the less dense spruce braces that are made taller will have more stiffness for a given weight (or lighter weight and the same stiffness)
After all, it is the stiffness to weight ratio that we should be concerned with.
When I was building with Engelmann tops in the 1980's, I used Engelmann bracing almost exclusively.
PostPosted: Fri Aug 23, 2013 11:03 pm
I have had great success with Engelmann bracing.... As John says, we can adjust braces so easily by simply adding or removing a wee bit to their height that very often, the lighter/weaker pieces actually prove superior.
PostPosted: Sat Aug 24, 2013 3:31 am
First name: Tom
Last Name: West
State: Nova Scotia
Only so much energy that can be transferred to the top from the strings, so if one wants the top to move, reduce the weight. So as the others have pointed out, use the light stuff to make the top more responsive. That carries over to the brace on the outside of the top as well.
Tom
PostPosted: Sun Aug 25, 2013 11:59 am
Keep in mind that 2/3 or more of the mass of the top is the top itself. If you save 10% of the weight of the bracing, that's 10% of 33%, which is 3% of the total top weight. Given that it's difficult to determine the actual Young's modulus of the wood any closer than about plus or minus 10%, that's well within the margin of error. Also, do you really know exactly how stiff the braces need to be? Most of the time we're not working that close to the line.
The relationship between Young's modulus along the grain and density in softwoods looks pretty linear in the range of densities we see. However, if you plot it out as a straight line it doesn't go through the origin: a piece of wood with zero density would not have a Young's modulus of zero. Since that pretty much has to be the case, the relationship has to be nonlinear; we're just far enough from the origin that we can ignore that without getting into too much trouble.
From my measurements, I'd expect a piece of softwood with a specific gravity of .3 to have a Young's modulus (E) along the grain of about 6000 MegaPascals, and a piece with a SpG of .5 to be somewhere near 16,000 MpA. About 2/3 of the samples I've tested fall within 10% of that line plus or minus. Thus going from a SpG of .4 to .32, about a 20% decrease, moves the E value from 11,000 to about 7000, an almost 60% drop. It's still worthwhile to use the lighter wood to save some weight, just not as much so as you'd think.
These users thanked the author Alan Carruth for the post (total 2): Imbler (Tue Aug 27, 2013 4:20 pm) • Jschlueter (Mon Aug 26, 2013 4:55 am)
Users browsing this forum: Bing [Bot] and 26 guests
