It is currently Fri Jun 20, 2025 7:31 pm
PostPosted: Mon Sep 02, 2013 8:40 pm
City: winnipeg
State: manitoba
Country: canada
I am working on a 12X12, type A style, 18 3/4" scale mandola.
The location of the UTB leaves me with little room for the sound-hole.
I am considering using sound-ports on both sides (aprox. 1" dia.) or a 2" dia. hole very near the heel-block.
Any opinions or horror stories would be appreciated.
Bob :ugeek:
PostPosted: Wed Sep 04, 2013 4:36 am
First name: Christophe
Last Name: Mineau
City: Louannec
State: Brittany
Zip/Postal Code: 22700
Country: France
Hi,
Maybe you've heard about this Helmholz resonance law :
"The ideal size of the sound hole should be the surface area of a circle, which radius would be the 1/4 of the radius of a sphere that would have the same volume as the soundbox" oops_sign
Easier : take you soundbox volume V
Calculate (V / 4.188) then take the cubic root (^(1/3) )
Then divide per 4
You get the radius of a round sound hole.
If you divide your sound hole in several ports, the total surface must be equivalent.
I've read that Helmholtz's research was based on violins, so the same range of frequencies as the mandolin.
For a guitar frequency range, it is reported that you must apply a correction of an average of 17%
Of course, this is pure theory and I have not build enough instruments to have a critical opinion on that theory.
Last word, for those who wish to calculate precisely the surface area of any odd shape : the trick is use Inkscape.
Christophe Mineau
Let's make chips ! - http://www.labellenote.fr
These users thanked the author Christophe Mineau for the post: eryops (Wed Nov 06, 2013 8:44 am)
PostPosted: Wed Sep 04, 2013 4:01 pm
City: winnipeg
State: manitoba
Country: canada
Christophe:
That is the first time that I have heard of it but it gives me a place to start. It looks like I will have to dig out my old log tables to figure a cube-root but it will work.
I have discovered that the fret board will cover the preferred part of the soundboard so I will have to use the sides.
Next time, I will do more planning before I brace the soundboard.
Thanks for the lead.
Bob :ugeek:
PostPosted: Wed Sep 04, 2013 4:53 pm
Last Name: Mineau
City: Louannec
State: Brittany
Country: France
Hi Bob,
Don't you have the possibility to put a fretboard extender over the hole ? like on a F5 ?
You could also go for ff holes ?
To come back ti the sqare root, you don't need your log tables anymore :) you have online calcs like this one:
http://www.picalc.com/
Bye,
Christophe
Christophe Mineau
PostPosted: Thu Sep 05, 2013 9:10 pm
City: winnipeg
State: manitoba
Country: canada
Christophe:
The calculation requires a cube root which is not on my calculator but I will give you the long process that I used so that someone else can use it as a guide (or a bad example).
I weighed the soundboard template and a measured piece of the same sheet of plywood. the area was calculated based on weight.
I averaged the height of the ribs and calculated the volume of the box.
I used your formula and calculated the cube root by iterations and divided by four.
The result seems low at 1.7675" dia. or 2.45 square inches.
Thank you for your help.
Bob :ugeek:
PostPosted: Fri Sep 06, 2013 1:25 am
Last Name: Mineau
City: Louannec
State: Brittany
Country: France
Hi Bob,
Take care, as I said, this is only theory, so just a starting point.
I will try to calculate it on the different mandos I have to see where it is exactly.
For the square root, take the online calculator I gave you the link above
For square root, you elevate at power 1/3 (sorry my mathemetical english is approximative)
for instance cubic root of 3 : type 3 Xy ( 1 / 3 ) =
And for the surface calculation, it is a bit for the geeks, but I explain how I do it with Inkscape software on my site :
http://www.labellenote.fr/articles.php?lng=en&pg=273
(sorry, still in Franch, I will translate that today)
Christophe Mineau
PostPosted: Fri Sep 06, 2013 3:32 am
Are you basing this instrument on an existing plan, or is it your design? As irritating it is to hear it, drawing it all out in full size before you start cutting wood usually avoids this type of problems...
For now, it sounds like a shorter fingerboard should solve your problem.
PostPosted: Fri Sep 06, 2013 11:29 pm
City: winnipeg
State: manitoba
Country: canada
Arnt:
You are correct.
I am waiting for an order of spruce and decided to go ahead with a three piece soundboard. I do not want to put "F" holes across the soundboard joints as they are fairly narrow strips on either side. I have decided to put one inch diameter holes on both sides and extend the reinforcing veneer to allow an additional hole to be drilled on each side. I intend to string it up in white and alter it as required.
Thanks for your help.
Bob :ugeek:
PostPosted: Mon Oct 14, 2013 12:58 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Violin builders won't finalize the f-hole shape and size until the instrument is done. They then tweak them to adjust the instruments overall sound.
Another day, another dollar.
PostPosted: Sun Nov 17, 2013 3:50 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I would guestimate a slight undersized f holes as above and enlarge if it did not look right when you eyeballed it ,just before final sanding and prior to finishing.. Wasn/t there an article abt making mandola/s in a recent issue of GAL?. You might want to check the GAL website and read the article/photo even if your not a GAL member. Guild of american luthiers .
