It is currently Sun Jul 27, 2025 7:00 pm
 Post subject: Making Purfling
PostPosted: Tue Oct 08, 2013 3:44 pm
First name: EddieLee
Last Name: Brown
This is my first try at making (at least in part) purfling. I have a 55 mil strip of cherry and I want to glue a piece of 20 mil thick BW purfling to side. What is the best way to do that?
I am leaning toward using CA. If I use CA will it still bend ok in a bender with a heat blanket?
_____________
EddieLee
 Post subject: Re: Making Purfling
PostPosted: Tue Oct 08, 2013 4:07 pm
Titebond III works well.
tim...
PostPosted: Tue Oct 08, 2013 4:29 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
+1 on titebond III. I have bent split side pieces glued with CA, the glue held okay but the fumes were very irritating while bending.
Bryan Bear PMoMC
PostPosted: Tue Oct 08, 2013 5:29 pm
titebond original is fine too .. all I use except fish glue on coco ...
PostPosted: Wed Oct 09, 2013 3:52 pm
Last Name: Brown
Thanks, but if you use titebond, how do you clamp up any thing that small. My thought is to assemble the cherry strip and the 2 BW strips and then bend it. That way I will have only the binding and 2 pieces of purfling to deal with when I bind the guitar. If I do not per-assemble it, I will have the binding plus 5 pieces of purfling flopping around during binding. That seem like a nightmare.
_____________
EddieLee
PostPosted: Wed Oct 09, 2013 4:01 pm
First name: Christophe
Last Name: Mineau
City: Louannec
State: Brittany
Zip/Postal Code: 22700
Country: France
Hi,
Have a look at this setup :
http://www.grellier.fr/article.php?id=6&lang=en
maybe it could help ?
Christophe Mineau
Let's make chips ! - http://www.labellenote.fr
PostPosted: Wed Oct 09, 2013 4:47 pm
Last Name: Brown
Thanks Chrisrophe. I think I could make something like that work.
_____________
EddieLee
PostPosted: Wed Oct 09, 2013 9:50 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
This thread is helpful to me as well. Any other approaches to glueing the purfling to the binding prior to bending?
Doug
PostPosted: Thu Oct 10, 2013 6:56 am
One way is to laminate a board of whatever height you want your binding and at least 3" wide with a layer of veneer then slice off pieces of appropriate width. That way I get enough for several guitars. I use fish glue.
Here's one with the single layer of veneer.
Edit: I should have read the original post closer - this won't help if you're trying to do narrow strips.
Users browsing this forum: peter.coombe and 18 guests
