It is currently Sun Sep 21, 2025 2:02 am
PostPosted: Sat Oct 12, 2013 4:15 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
Where is the center point of a braced top in regard to a radius dish? Is it the center of the X-brace? Thx.
PostPosted: Sat Oct 12, 2013 4:29 pm
Last Name: G
Doesn't matter with a radius dish because the radius is constant, or the same, everywhere in the dish.
cheers
These users thanked the author SteveG for the post: Steven Bollman (Sat Oct 12, 2013 5:06 pm)
PostPosted: Sat Oct 12, 2013 4:57 pm
I do not use a complete radius for the top plate and my center point (or highest point) is in front of the bridge, more or less close to the center of the x brace.
Burton
Brookline, MA.
These users thanked the author Burton LeGeyt for the post: Steven Bollman (Sat Oct 12, 2013 5:06 pm)
PostPosted: Sat Oct 12, 2013 5:06 pm
First name: Steven
Last Name: Bollman
City: Emeryville
cheers
Well, if I don't use a radius dish, how do I know where to establish the center point? I'm going to use 3x5 index cards.
Sent from my iPhone using Tapatalk - now Free
PostPosted: Sat Oct 12, 2013 6:45 pm
First name: duh
Last Name: Padma
Good question!
Being an arch top carver, me likes to place the high point of both plates at the bridge. But as Steve pointed out, a radius is a constant even though in reality this is no constant in the universe ...seems that even the speed of light is a variable. So about the only "constant" we can count on is change and umm death. Now what?
These users thanked the author the Padma for the post: Steven Bollman (Sat Oct 12, 2013 7:09 pm)
PostPosted: Sat Oct 12, 2013 7:09 pm
First name: Tom
Last Name: West
State: Nova Scotia
Steven: I have a couple of dreads here and just looked at them. The high point "looks like" it's somewhere between the narrowest part of the waist and the lower edge of the sound hole. I must say that I don't intentionally work to do that but it just happens as a result of how I work the top edge of rims. The rims are basically worked to get .500" between the top and the bass E with about .095" action at the 12th fret.
Tom
PostPosted: Sun Oct 13, 2013 12:43 am
First name: Steven
Last Name: Bollman
City: Emeryville
Todd Stock wrote:
If the top retained a true radius, it would be mid way from tail to neck joint, or 10" in from the tail block on a 20" long body. If the guitar is built with a combination radius (e.g., 28' for X and 60' for UTB, there may be a slight shift towards the tail, but still likely very close to mid-body, which is where the X-intersection will sit.
Thanks, Todd. BTW, what is UTB?
PostPosted: Sun Oct 13, 2013 2:16 am
Last Name: G
Upper Transverse Brace - It's the brace across the upper bout that gets notched into the lining.
These users thanked the author SteveG for the post: Steven Bollman (Sun Oct 13, 2013 10:19 am)
PostPosted: Sun Oct 13, 2013 11:52 am
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, Steve. Is it the baseball bat?
PostPosted: Sun Oct 13, 2013 1:16 pm
Last Name: G
Ha. When I hear baseball bat I think of old Gibson necks... Dunno about them regarding bracing.
On a modern dread there are 2 braces that go across (or almost across) the upper bout on the top bracing. The one that's glued on flat is the top plate or popsicle brace. The other one is not as wide but thicker and is notched into the lining, and that's the UTB or number one brace. It's the one that often has a "flatter" radius than the other braces on the lower bout.
cheers
