It is currently Thu Aug 14, 2025 2:09 am
 Post subject: Which Menzerna?
PostPosted: Tue Oct 15, 2013 1:13 pm
Last Name: Sollod
I have had reasonably good success using Stew-Mac ColorTone polishing compounds and foam pads on a drill clamped into a vise. I typically will wet sand EM6000 using odorless mineral spirits and 1000 grit wet/dry paper, followed by the ColorTone, coarse, medium, and fine liquid compounds. But, I’m thinking of stepping up my game.
With two buffing wheels which two of the Menzerna compounds should I get? I see that LMI has 5 grades… If I wet sand with 1000 grit paper, can I use fine and very fine? Should I use 1200 or higher paper? I’d prefer to limit the number of buffing wheels to 2. Are more wheels necessary or desirable? Any guidance is appreciated.
www.swiftcreekguitars.com
 Post subject: Re: Which Menzerna?
PostPosted: Tue Oct 15, 2013 2:05 pm
I use medium & fine (on nitro) then a swirl remover polish by hand.
PostPosted: Tue Oct 15, 2013 2:13 pm
Last Name: Sollod
Here are the choices from LMI…
Menzerna stick, 600 grit (dark brown color)
Menzerna stick, 800-1000 grit (salmon pink color)
Menzerna stick, fine grade (ivory color)
Menzerna stick, very fine grade (olive color)
Menzerna stick, finest grade (tan color), smaller bar
PostPosted: Tue Oct 15, 2013 6:14 pm
Stew Mac calls them course, medium, fine & extra fine.
I bought mine from Shane @ High Mountain and he designates them as #18 medium & #16 fine.
If you have additional buffs, you could by 3 different compounds and just change out the buff.
I fine for lacquer that the medium & fine work we'll with the hand polish swirl remover after it's all together.
PostPosted: Tue Oct 15, 2013 10:24 pm
#18 is no longer available from Menzerna. They have replaced it with P204. I have been using the P204 for a few months and I like it better than the #18. It smells better and is a "dryer" compound bar. Seems like less mess too. You may still be able to find the #18 at some venders that have some old stock.
jw ( o)===:::
PostPosted: Thu Oct 17, 2013 8:27 am
I'd suggest wet sanding to 2000 & then using med. & fine on EM6000. This has worked well for me.
Milton, ON
cron
