It is currently Sat Aug 09, 2025 3:09 am
PostPosted: Fri Jan 31, 2014 9:14 am
First name: Larry
Last Name: Hawes
I know this topic is very old but it seems like the landscape of finishing options changes very rapidly and I'm curious as what builders are using today, or on your next guitar?
My last 4 were (mostly) finished with Sutherland Welles U500 which is really good product IMO but I also used some Epifanes on 2 tops and it's also a great product.
I've used the Poly Whey water borne, KTM 9 and 10 (10 will most likely not see the light of day I learned the other day) Sutherland Welles, Min Wax Oil based Polyurethane, and a couple I think I'm leaving out. Oh yeah tried Crystal-Lac at one point. I've never used Nitro or shellac/French Polish.
My next build I'm considering using the SW on the top as a wipe on to keep the film very very thin and then maybe going back to the Poly Whey water base or even trying the KTM-9 again as they are so easy to apply and finish.
What are you using these days?
Thank You and Best To All
PostPosted: Fri Jan 31, 2014 9:39 am
I've used Tru Oil, EM6000, PolyWhey, and nitro. At the moment I'm still with the nitro although I may go back to the EM6000 just cause the nitro stinks up my shop so much.
PostPosted: Fri Jan 31, 2014 10:04 am
First name: Larry
Last Name: Hawes
EM600 over the PolyWhey? I think you introduce the board to the Poly Whey. Never used the EM6000, but might try it. Thanks Steve.
PostPosted: Fri Jan 31, 2014 11:22 am
ICA PF5051 polyester. Going on three years with it now.
jw ( o)===:::
PostPosted: Fri Jan 31, 2014 11:29 am
French Polish unless otherwise requested. Ive tried a few different water based solutions and gave up on them since I could not be consistent. Lacquer I can only spray when the weather permits since I will only do that outside.
PostPosted: Fri Jan 31, 2014 11:39 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I'll probably stick with nitro on steel string guitars, but I will get someone else to spray it for me. That stuff is deadly. I've tried French polish on my zouks and it looked very nice but a bit soft for an instrument that gets bashed around so much (strummed heavy in Irish sessions). I like oil wiping varnish such as Liberon Finishing oil for zouks, for if Im going for the natural in-the-wood look. It's easy to apply, thin (almost no build), no pore filling, brings out the depth of the wood and leaves a nice semi-gloss sheen. It provides the best tone I think since there is no build. There is immediate volume and clarity with no break in period. Not as durable as nitro though.
PostPosted: Fri Jan 31, 2014 12:48 pm
EnduroVar
PostPosted: Fri Jan 31, 2014 1:00 pm
I did jump on the PolyWhey to try it but Colin N (I think) introduced the board to it. I prefer the EM6000 to the PolyWhey.
PostPosted: Fri Jan 31, 2014 1:09 pm
First name: Larry
Last Name: Hawes
Thanks Steve
PostPosted: Fri Jan 31, 2014 1:29 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
I brushed PolyWhey on my first two except for the tops which were French polished. I've French polished the last five. I've only built classicals so far and somehow gravitated to French polishing, although I'm not as good as I'd like. Got the turbine for HVLP spraying and will be trying it in the future when the weather gets more cooperative, since I would have to spray outside.
PostPosted: Fri Jan 31, 2014 1:37 pm
A slight aside....
Where did you hear the KTM 10 won't see the light of day? I've been waiting on it!
I've been using KTM vs for gloss.
PostPosted: Fri Jan 31, 2014 1:57 pm
Last Name: Vallandigham
City: Martinez
I spray catalyzed oil varnish. Up till now, I've used Ace interior varnish. I'm looking for something else, as it seems to stay soft for a few months. It does harden up, but not like nitro.
I'm going to either switch to another varnish, or try some japan drier in the mix.
When I forst tried this, I was adding about 10% acetone to the mix for spraying ease and lay down. I've cut this back to about 5%, and it seems to have cause the varnish to dry harder. Not sure why, as you'd think the acetone would flash of instantly...but...
I'm not too keen on the Epiphanies stuff, being Spar varnish. It seems people add a bunch of additives to this brand to get it to dry hard.
PostPosted: Fri Jan 31, 2014 2:10 pm
Last Name: Matthews
State: Surrey
Country: England
Epifanes spar varnish http://www.epifanes.com/home.htm
http://www.bobmatthewsguitars.co.uk
PostPosted: Fri Jan 31, 2014 2:31 pm
There's only one way to get oil varnish to dry harder and that's to increase the resin to oil ratio. I can't think for one moment why adding a drier or solvent would make the varnish film harder. It will dry the varnish faster though, which is probably what people are experiencing. Oil varnish (and Shellac) takes a long time to reach full hardness.
PostPosted: Fri Jan 31, 2014 2:48 pm
How long is long?
PostPosted: Fri Jan 31, 2014 3:38 pm
First name: Corky
Last Name: Long
City: Mount Kisco
EM6000 over Zpoxy.
PostPosted: Fri Jan 31, 2014 3:40 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Behlen rockhard thinned with turpentine an 10 percent acetone
Sent from my SGH-T999L using Tapatalk
PostPosted: Fri Jan 31, 2014 3:51 pm
Last Name: Sollod
EM6000 over Zpoxy, same as Corky...
www.swiftcreekguitars.com
PostPosted: Fri Jan 31, 2014 4:03 pm
CharlieT wrote:
How long is long?
That probably depends on the individual varnish. You might have to start thinking in terms of a year and longer. We know that shellac undergoes changes over decades, which is why some types become insoluble in alcohol.
These users thanked the author Michael.N. for the post: CharlieT (Fri Jan 31, 2014 6:11 pm)
PostPosted: Fri Jan 31, 2014 4:27 pm
First name: Larry
Last Name: Hawes
meddlingfool wrote:
A slight aside....
I talked to the rep the other day because I was waiting for it as well. I'm paraphrasing but he said they actually had enough negative feedback, about 20%, to cause them to reconsider the formula and whether or not to market it. Short version, some adhesion problems, and even those who thought it got too hard.
I loved it but its future didn't sound too promising after our converstaion. Maybe give them a call and request it, might change things.
PostPosted: Fri Jan 31, 2014 6:14 pm
Thanks Michael. That's what I was afraid you might say. ;)
I used EM6000 over epoxy on my first two and plan to give Sutherland Welles U500 a try on my current build.
PostPosted: Fri Jan 31, 2014 6:50 pm
Last Name: Russell
State: Michigan USA
I use Behlen Stringed Instrument Lacquer on top of their Vinyl Sealer...
Nothing else.
Thinking about doing some French Polishing on my first build. Many moons ago I worked at a furniture factory as their final inspector/ repair guy where I learned how to do French Polishing from a real old timer and got pretty good at it... but that was many moons ago so I would like to have a go at it again.
Cheers,
Bob
PostPosted: Fri Jan 31, 2014 8:47 pm
Last Name: Fifield
City: San Jose
Zip/Postal Code: 95124
I just finished a nylon crossover (SJ body with cutaway, fan braced) with Wipe-On-Poly as an experiment. I was pleasantly surprised how easy it was to use, how thin it is (sound remains basically unaffected from in-the-white) and how good it looks (not mirror finish, but pretty shiny). It took 12 thinly wiped on coats (with fine sanding between every two) to get there though. The reason for trying this? It's too cold to spray successfully in my 'shop this time of year. I'll be using it again, for sure.
Cheers,
Dave F.
Cambrian Guitars
PostPosted: Sat Feb 01, 2014 9:32 pm
Nitro, FP. After hearing no difference between nitro and FP, dont think I'll do FP any more though.
PostPosted: Sat Feb 01, 2014 9:59 pm
Last Name: Russell
State: Michigan USA
Just curious....
Does anyone use Tung Oil as a finish on the box? I have done a number of necks with it and they feel silky smooth. I have also used it on a couple of furniture projects in the past and given enough coats it is difficult to tell from nitro. I have never heard of anyone finishing a guitar body and was wondering if there is a reason.
Cheers,
Bob
Users browsing this forum: No registered users and 40 guests
