It is currently Fri Aug 08, 2025 5:51 am
 Post subject: Jet 10/20 problem.
PostPosted: Sat Feb 01, 2014 7:42 pm
This just started happening the other day. I've had this for a few years and have not had any problems. Any ideas on what might be going on? This was a brand new piece of sandpaper two passes ago. The paper overlapped and it tore just at the attachment point.
Thanks.
Wisdom is justified by her children
 Post subject: Re: Jet 10/20 problem.
PostPosted: Sat Feb 01, 2014 7:43 pm
I hate when that happens.
PostPosted: Sat Feb 01, 2014 8:20 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
what kind of paper?????
MK5acoustics.com
PostPosted: Sat Feb 01, 2014 8:43 pm
Can't remember wher I got it. There is no name on the paper. It's an X weight aluminum oxide. Pretty sure I got it from an OLF member recommended source ;/
PostPosted: Sat Feb 01, 2014 9:11 pm
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
Something similar happens to me when I put on a new roll. I have found it is because the paper is not tight enough and is slipping, because it is not tucked in to the clip as far as possible. It takes me a few times of running the drum, finding which clip is not tight enough, adjusting, and running again. When it seems to be tight enough, I start running scrap wood through to see if there is anymore slippage.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
These users thanked the author Kevin Mason for the post: Mark Maquillan (Sat Feb 01, 2014 9:34 pm)
PostPosted: Sat Feb 01, 2014 10:21 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
try some klingspor, I use the 80 grit , I have a template drawn on my work table and just cut what I need ...http://www.woodworkingshop.com/product/pe40210/
MK5acoustics.com
PostPosted: Sun Feb 02, 2014 7:54 am
Some roll abrasives seem to stretch when used and require periodic re-tightening. I've had that happen with sanding belt as well. I listen to my drum sander and it sounds a little different when the abrasive needs to be re-secured.
Users browsing this forum: Bing [Bot], Ken Lewis and 25 guests
