It is currently Sat May 23, 2026 11:42 pm
PostPosted: Mon Mar 03, 2014 3:00 pm
I need to remove the rosewood binding from a cocobolo fretboard. The good news is the fretboard is not attached to anything. So my plan is to go at it with a razor blade (from the back) with heat or acetone. The binding was glued with CA. I think I am going to somehow heat the razor blade. Any other ideas are welcome. Thanks.
PostPosted: Mon Mar 03, 2014 3:07 pm
Why not just cut it off?? Fastest way. Or are you trying to save the binding?
CA will dissolve with acetone, you don't need heat.
PostPosted: Mon Mar 03, 2014 3:10 pm
A wood plane would make quick and fun work of it.
PostPosted: Mon Mar 03, 2014 6:38 pm
I was thinking it would be quite easy to save the binding. Binding was pretty cheap so maybe I should just cut it off. I was debating doing a bamboo binding so it matches the inlays, just need to figure out keep the bamboo from blowing up (literally) when I use the router.
Hoping that the acetone will not stain the fretboard.
PostPosted: Mon Mar 03, 2014 7:09 pm
It shouldn't. Test on scrap.
PostPosted: Tue Mar 04, 2014 9:47 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Hand plane
Typhoon Guitars
PostPosted: Wed Mar 05, 2014 5:40 am
Why don't you use an edge sander and sand it off, but not all the way. Leave like a 32nd of an inch or something, make it an accent stripe.
Old growth, shmold growth!
PostPosted: Wed Mar 05, 2014 4:40 pm
Thanks all. The acetone did not cause any staining. It also did not free the binding, at least not easily with the razor blade. I even poured the acetone on, but it seems the acetone needs to make contact with the CA, and I suppose that wasn't happening. I have removed a few bridges with careful use of the hair dryer, I will try that next. After that I will just plane it off, I don't have a sanding station. I am not sure what an edge sander is.
PostPosted: Wed Mar 05, 2014 6:53 pm
Heat doesn't work on CA. Don't waste your time trying.
PostPosted: Wed Mar 05, 2014 7:25 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
Yes, I've wondered how well acetone would work to disassemble parts. It does dissolve CA, as I've used it for spills, but it doesn't seem too aggressive and it evaporates very quickly. It may not remain liquid well enough to stay and eat away at the glued seam,
These users thanked the author Imbler for the post: Rod True (Wed Mar 05, 2014 8:07 pm)
PostPosted: Wed Mar 05, 2014 8:41 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
CA has very low shear strength... you may be able to dislodge it with a few taps on its side...
Typhoon Guitars
PostPosted: Wed Mar 05, 2014 10:03 pm
If your not trying to save the binding, save your self the trouble and time and cut it off.
These users thanked the author LanceK for the post: Rod True (Thu Mar 06, 2014 10:11 am)
Users browsing this forum: No registered users and 119 guests
