It is currently Sat May 16, 2026 10:13 am
PostPosted: Wed Mar 26, 2014 3:20 pm
A woodworker sells these bits of Welsh slate he processes on Ebay, and estimates they are roughly equivalent to about an 8000 waterstone ( He also has higher grits)
At about a third of the price of a cheap Japanese waterstone 8000 grit.
Could be worth a look, no?
So mine arrived today, and I needed a sharp chisel for a work in progress, so -
New Ashley Iles 1" chisel, worked the back up through the diamond grits 400/1200/8000.
Then went to the Dragon's Tongue, worked up a slurry with the supplied rubbing stone, and started polishing the back.
It's a bit slow, but seems not bad at all, and is certainly a higher grit than my DMT 8000.
And it of course gave a better edge than I got with the DMT 8000, even though it's been quite well used for a few years after breaking it in with a Stainless Steel block.
Have look yourself - what do you think?
I don't need this fine an edge all the time, but it's good to have available when you need it.
PostPosted: Wed Mar 26, 2014 4:26 pm
I don't have that particular stone but I do have a slate stone that someone gave me a few years ago. As you said, it cuts a bit slower than an 8,000 waterstone. It's not as slow as my Arkansas though. I think you could do a lot worse than Slate for use as polishing media, especially at the price.
This isn't too bad either:
http://www.amazon.co.uk/Kitchen-Master- ... ss+diamond
My first dip into diamond stones. I like it. I like it a lot. Just depends how long it lasts. I've been using it regularly for 3 months and so far it's still cutting well. That and the slate is probably all that is required. Somehow I've ended up with far too many stones.
PostPosted: Wed Mar 26, 2014 6:00 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thanks for the headsup Colin. how hard is it?
PostPosted: Wed Mar 26, 2014 6:22 pm
Last Name: Ward
Country: UK
I use a set of 3 of these, admittedly I often stop on the 8000ish one, but I like them.
Sent from my D5503 using Tapatalk
PostPosted: Wed Mar 26, 2014 7:24 pm
Pretty dang hard, and doesn't break down relatively easily like japanese waterstones when making a slurry (although they vary quite a bit)
http://www.infotile.com/pdffile/advicetopic/34201054307.pdf
Have a look at Table 6
Welsh slate is about the hardest slate around.
So, between the hardest marble and quartzite/basalt, (or the lower end of granite)
Users browsing this forum: No registered users and 283 guests
