It is currently Sun Apr 26, 2026 4:08 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jun 09, 2014 8:06 am
Please post a pic of your cans.... the Duplicolor, I mean.
PostPosted: Mon Jun 09, 2014 8:30 am
Last Name: Avant
City: Tuscaloosa
State: AL
Zip/Postal Code: 35401
Will do at lunch. Ish...
Moobs...
PostPosted: Mon Jun 09, 2014 12:11 pm
Last Name: Avant
City: Tuscaloosa
State: AL
This is they.
PostPosted: Mon Jun 09, 2014 1:21 pm
Well, your clear is lacquer - as stated.
Blue metallic - might be a clue on the back, something about toluene, etc.
PostPosted: Mon Jun 09, 2014 5:57 pm
Last Name: Avant
City: Tuscaloosa
State: AL
The clear coat has it listed. The paint lists nothing.
PostPosted: Mon Jun 09, 2014 6:04 pm
First name: D
Last Name: S
Make sure the clear is compatible with the color. I pulled up several data sheets at their website. Acetone and two other solvents on their acrylic lacquer, but the material was not disclosed. If the color is enamel, I'd bet the clear is not compatible. Also, nitro lacquer is not compatible with acrylic lacquer.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Jun 09, 2014 6:08 pm
First name: D
Last Name: S
dzsmith wrote:
Make sure the clear is compatible with the color. I pulled up several data sheets at their website. Acetone and two other solvents on their acrylic lacquer, but the acrylic material was not disclosed. If the color is enamel, I'd bet the clear is not compatible. Also, nitro lacquer is not compatible with acrylic lacquer.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Jun 09, 2014 6:11 pm
Last Name: Avant
City: Tuscaloosa
State: AL
I will do a test tonight. I dont have any spare wood however. Do you think cardboard would work for a test?
PostPosted: Mon Jun 09, 2014 6:41 pm
Yup. Cardboard will work.
PostPosted: Mon Jun 09, 2014 6:44 pm
First name: D
Last Name: S
Sorry, I forgot to mention it looks great!
Love the metallic color!
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Jun 09, 2014 6:49 pm
Last Name: Avant
City: Tuscaloosa
State: AL
Thanks! Can't wait to see all the chrome on it. Updates to come.
PostPosted: Mon Jun 09, 2014 7:02 pm
Last Name: Avant
City: Tuscaloosa
State: AL
Cardboard w paint. Drying before clear coat test.
PostPosted: Tue Jun 10, 2014 8:06 am
Last Name: Avant
City: Tuscaloosa
State: AL
Here we are this morning after a thick spray of the clear coat. It looks ok. The texture seems normal.
Are there specific things I should be looking for with regard to compatibility between the base and the clear?
Seems ok...
PostPosted: Tue Jun 10, 2014 9:12 am
Well, your compatibility test seems OK at first glance.
When your apply your clear, if you see crazing or cracking of the base color - stop immediately.
Then we'll figure out the next step.
Good luck!
PostPosted: Tue Jun 10, 2014 9:20 pm
Last Name: Avant
City: Tuscaloosa
State: AL
Have begun the clear coating. No ill effects as of yet.
PostPosted: Tue Jun 10, 2014 9:49 pm
Last Name: Avant
City: Tuscaloosa
State: AL
PostPosted: Tue Jun 10, 2014 11:12 pm
Looking fine as frog fur.
PostPosted: Wed Jun 11, 2014 10:00 am
First name: sean
State: nm
Zip/Postal Code: 88349
Country: us
If your base and clear react bad with each other, you will know pretty quick (before it dries) when it turns to cottage cheese in under 10 minutes flat. It used to be cut and dry, paint cans said lacquer or enamel right on the front, and you never mixed the two (though you could use enamel over the top of lacquer). For whatever reason, manufactures have gotten sketchy on it these days.
Finding lacquer primer in a rattle can is impossible now, for what its worth, Rustolium automotive primer will take lacquer over the top even though you cant get good info on it.
Your paint looks good!
Whatever you do DON'T confuse me as an EXPERT, or MASTER, just a self learned trial and error guy. I had to build a dozen guitar before I found out what a "Luthier" even was (????)
PostPosted: Wed Jun 11, 2014 9:11 pm
Last Name: Avant
City: Tuscaloosa
State: AL
Thanks! Two cans of clear applied. Need to figure something out for the head stock, and get one more can of clear for the neck. Then. Curing...Image
