It is currently Tue Aug 05, 2025 3:29 am
PostPosted: Thu Aug 21, 2014 6:25 pm
I have a customer nosing about for a redwood top, possibly with the curly figure. I recall a thread here once where the bridge basically ripped up and destroyed the top along the figure lines.
Does anyone here have any experience that they could share about redwood in general, curly in particular?
Thanks...
PostPosted: Thu Aug 21, 2014 6:50 pm
Last Name: Kincheloe
Talk to Harvey Leach :) http://www.acousticguitarforum.com/forums/showthread.php?t=317753
PostPosted: Thu Aug 21, 2014 8:13 pm
State: ON
My experience was not good, I had one of those bridge-ripped-the-top-apart along the figured lines issues. Ended up re-topping that one for the customer with some bear claw spruce. I've heard a lot of guys suggest double-tops when using curly redwood, but since I have no interest in double-tops I've never tried it.
With some different treatment my top probably could have worked. I just didn't adjust the thickness and bracing enough to compensate for the weakness of the top. This was also early in my building career when I didn't have the experience I do now. Since I don't want to risk anything like that again I continue to avoid it.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Aug 21, 2014 11:52 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
The stuff I had was pretty soft. Running the laminate trimmer around the rim left a slight impression. It also likes to tear out and needs to be left relatively thick and or stiffly braced. My box was gorgeous but unfortunately that's the one that hit the shop floor while wet sanding the finish :/
PostPosted: Fri Aug 22, 2014 4:18 am
First name: steve
Last Name: barbour
Country: U.S.
Some of the suggestions that were made to me when I inquired about curly redwood tops were- make the bridge plate slightly wider(from neck to tail). Leave the top slightly thicker than a straight grained redwood top. Flood the top with CA glue. Make the footprint of the bride larger, you can use a lighter wood to keep the weight of the bridge down. I used a walnut bridge. It's only been a year since I finished the guitar but there are no signs of problems so far. I intended the guitar to be for myself but someone really took I liking to it. I made them aware of potential problems before handing it over. Keep in mind this was my fifth guitar so my experience is limited. There are certainly others who can give more qualified answers but thought the suggestions I received would help.
Kyle
PostPosted: Fri Aug 22, 2014 11:21 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
I did this one for a challenge a while back. That's a pinless bridge, and it stayed on.
I've replaced it with a pinned bridge, and that is fine also. I think some curly redwood is problematic, some is not.
PostPosted: Fri Aug 22, 2014 12:59 pm
Last Name: Giltzow
City: Boise
State: Idaho
Zip/Postal Code: 83709
I like the looks of the redwood top and I really like the sound of the only one I have built. Still it worries me that so many people have had trouble with redwood tops. If you like the looks and sound I guess you just have to take the chance. Plan to replace any mistakes and let the owner know you'll make any repairs necessary. This guitar is now 3 years old - so far no problems
guitarsbygiltzow.com
PostPosted: Fri Aug 22, 2014 1:07 pm
Sure is pretty stuff!
PostPosted: Fri Aug 22, 2014 6:10 pm
Hmm, a crapshoot I guess...
PostPosted: Sat Aug 23, 2014 12:21 pm
There is curly redwood and then there is curly redwood. Over the years we have cut a lot of curly redwood and have found that it varies greatly in density. The sinker redwood is much denser and stiff in both directions. This makes for a good top with a very slim chance of a bridge ripping off. It will hardly flex along its length. The light weight material should not be used as an acoustic top. It can be used as a drop top or over spruce as a double top. It is very weak along the curl lines and will flex along the length to the point of snapping.
