It is currently Sun Aug 03, 2025 5:31 pm
PostPosted: Sat Nov 01, 2014 7:34 pm
Last Name: Beaver
City: Lake Forest
I'm thinking about including a bound fingerboard and headplate on my next build. I was wondering how you do it?
Bind the fingerboard before gluing to the neck?
Do you put a full 1/4" binding on the headstock? Or do you just match the bottom edge with the FB?
Tips on how to do it?
Pictures?
Any help is appreciated.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 01, 2014 8:53 pm
I slot it, taper it, then bind it before it gets attached to the neck. Never done a headstock...
PostPosted: Sat Nov 01, 2014 9:41 pm
Last Name: Russell
State: Michigan USA
I bound my Vintage Parlor fretboard with the same ebony I used for the fretboard. I just cut the strips off first and then glued them back on after doing the fret slots. I was going after a specific look with using the same material and rounding the ends of the frets off. I didn't bind the headstock.
But here is a shot of what I did. Sorry I don't have any in progress shots but you get the idea. The point was to not have the frets show from the sides and give the round cutout a similar look to the 1800's parlors that had the frets install right on the top.
Bob
Edit: I did glue the binding on prior to gluing it on the neck.
PostPosted: Sat Nov 01, 2014 9:53 pm
Last Name: Beaver
City: Lake Forest
Ed,
I was thinking that would be the way to go. I did see a video on you-tube where he mounted the slotted board on the neck then bound it. it did seem counter-intuitive to me.
For the headstock I guess I could just mount the headplate as usual then route around it with a dremel.
Rus,
That does look nice. Thanks for sharing
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 01, 2014 11:25 pm
Last Name: Kincheloe
Slot, taper, bind, glue onto neck. Some people include wide purflings on the fingerboard, which are also slotted, and only the binding solid. But if I do purfling, it's usually only one veneer layer, so I just leave that solid too so I can glue it all at once.
Clamping the binding can be a bit tricky. I use hide glue, and squeeze the glue out with my fingers at first, and then stick 6-8 strips of masking tape on as tight as I can, and squeeze more with fingers for a couple minutes. Then clean the glue out of the slots with an x-acto knife while it's still wet (for best results, take an old blade with the tip broken off, and grind it to a chisel-type shape). If the binding has a side purfling strip pre-glued to it, you have to be really careful to get it level with the bottom of the fingerboard.
Fretting bound boards is more time consuming, trimming away part of the tang to overhang the binding. You can make a tang nipper tool out of a sheet metal nibbling tool, though it still takes a little file work to get the underside of the fret fully flush.
I like headstock binding to be equal to the headplate thickness, though there are other styles that can look good, especially if side purfling is involved. Dremel works for routing, or you can do it by hand with gramil and chisel.
PostPosted: Sun Nov 02, 2014 12:09 am
First name: Danny
Last Name: Vincent
Do the FB before you glue it to the neck. I use my Fleishman binding cutter to do the headstock. Just take off the depth of the headplate and then it will come out flush with the nut slot if you can picture that. Bind the headstock BEFORE gluing the FB on. It doesn't work so well the other way............... so I hear. :oops: That's one way. Here's some other ways.
viewtopic.php?f=10102&t=10285&p=141737&hilit=+binding+headstock#
That's an old one.
PostPosted: Sun Nov 02, 2014 1:20 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Bind the fingerboard first. I use 1/8" shock cord as a clamp for the finger board binding. Install any dots, then scrape the bottom flush and drum sand the binding and dots flush, finish sand by hand and install frets. Then glue to the neck. I use a piece of marble shaped like the fingerboard for a caul on top of the frets.
My headstock is usually a jigsaw puzzle type inlay glued to 1/16" maple ply. Then I glue that to a piece of 1/4" MDF shape that to final headstock shape (I usually use a template and router) and use the same binding channel cutting setup used for the instrument top. Then drum sand the inlay and bound headstock flush, then saw off the excess MDF and drum sand the back down to the 1/16" ply. then I take that finished inlay/headstock an glue it to the roughed out head using a smooth sanded nut as a spacer (the nut fits perfectly every time this way). Then saw off the excess on the bandsaw and carefully sand or file down to the binding.
It sounds like a lot but it is a very logical progression and allows me to do very substantial headstock inly and binding quickly.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Sun Nov 02, 2014 2:58 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Joe Beaver wrote:
Do you put a full 1/4" binding on the headstock? Or do you just match the bottom edge with the FB?Tips on how to do it?
Hi Joe. I never liked the look of an unbound fingerboard, so I bind virtually all of my guitars, and many headstocks, and I often use both top and side purflings. You've identified a key aesthetic issue regarding height of the binding on the headstock and fingerboard, and how they line up. A look I don't like (although it is how I started) is in the following picture, where the intersection of the headtock and fingerboard binding looks awkward:
The look I go for is more like the following two photos, where the bindings/purflings line up in a pleasing way, both from the side and from the top:
It looks like the headplate is extra thick, but it's not. The key is a little wedge added to raise the point where the headplate meets the nut (do NOT do anything at the other end of the neck until the headplate is glues and cut to length at the nut):
I cut the headstock binding channel with the same Williams jig I use for the body. I clamp the neck to that the headplate is level, then cut around the headstock, to a depth that intersects the fingerboard plane:
I fit the binding and purfling pieces one-by-one, position with binding tape and glue with CA (of course the miters are the hard part):
I'll walk through the fingerboard in the next post.
These users thanked the author Tim Mullin for the post: TimAllen (Mon Nov 03, 2014 1:41 pm)
PostPosted: Sun Nov 02, 2014 3:12 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Like others have mentioned, I bind the fingerboard before attaching to neck. The board is slotted and tapered, such that the width is reduced by two times the summed thickness of binding and any top purflings. I first add the top purfling (with Titebond) and then the side purflings with CA. The following photo shows the clamping to the side purfling to the bottom edge of the binding, where I check carefully for alignment before wicking in thin CA:
My fingerboards have a curved end which is also bound. I start binding by gluing a short piece of binding+purfling to the end with CA:
The side pieces are fit with miters at the end, and clamped into position -- wax paper beneath, and a strip of UHMW plastic as a glue-proof caul. Once I'm happy with the fit, I wick in the CA, being careful not to get much if any into the slot (where it's a PITA to remove!):
The bound fingerboard is cleaned up, side dots added (I usually inlay shell dots), and the fingerboard is ready to attach:
Fretting is done after finish, using a tang nipper (Stewmac, I think) to fit the fret over the binding.
These users thanked the author Tim Mullin for the post (total 3): Robbie_McD (Wed Nov 05, 2014 11:32 pm) • TimAllen (Mon Nov 03, 2014 1:43 pm) • mkellyvrod (Sun Nov 02, 2014 10:08 am)
PostPosted: Sun Nov 02, 2014 10:09 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Very nice, Tim. Thanks for the pictures!!!
PostPosted: Sun Nov 02, 2014 10:47 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Tim , kudos and cheers vy nice clean and impressive work. Just started binding my FB/s too.
PostPosted: Sun Nov 02, 2014 10:53 am
There is no right way or wrong way.
PostPosted: Sun Nov 02, 2014 2:20 pm
I always bind the peghead veneer before I glue it on to the neck. No fuss, no muss. Same with the F/B and I use cya on the F/B.
These users thanked the author Haans for the post: mkellyvrod (Mon Nov 03, 2014 8:00 am)
PostPosted: Sun Nov 02, 2014 2:44 pm
Last Name: Beaver
City: Lake Forest
Great stuff guys! Tim, that is an excellent guide to 'how to do it'. Love your work!!! Thank you for posting.
Joe Beaver
Maker of Sawdust
PostPosted: Sun Nov 02, 2014 2:49 pm
Last Name: Beaver
City: Lake Forest
Haans, good looking work!!!
Joe Beaver
Maker of Sawdust
PostPosted: Sun Nov 02, 2014 3:36 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I routed the headstock binding after the headplate is mounted, and made it the same thickness as the headplate rather than having the Gibson look.... (picture 1 from Tim's first post).
However one thing that I always have trouble with is mitering. It sounds simple but to make it look completely seamless is rather difficult. It would be a lot easier to do the binding off the neck rather than on because oftentimes the chisel would cut too deep, and end up gouging the neck itself. Using plastic binding would make things much easier too.
I sometimes wish I could have a precision laser cutter to miter bindings exactly with exacting precision.
Typhoon Guitars
These users thanked the author Tai Fu for the post: CraigG (Mon Nov 03, 2014 11:54 am)
PostPosted: Sun Nov 02, 2014 8:46 pm
First name: D
Last Name: S
Thanks, Tim!
I'm gonna try the little ledge trick on my current build.
Very clever!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon Nov 03, 2014 8:00 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
You learn something new all the time. Haans, it never would have occurred to me to bind the veneer before it's glued to the headstock. Can I ask how thick is your typical veneer, and do you do this on slotheads as well? Thanks!
PostPosted: Mon Nov 03, 2014 9:20 am
Yea, it came to me when trying to bind F5 pegheads... :shock:
Woke up in the middle of the night with cold sweats and realized two things. Shape a 1" or so block to the shape of the peghead and cut off a slice when you need it. Bind it before gluing on the neck. Thickness of the veneer depends on the amount of garbage on the side of the binding. I usually go 1/8", glue it on and sand the veneer and binding flat after glue up.
For slots, you rout the slot after it is glued on and the neck shaped to the overlay. Just did one the other day.
Just too simple... [headinwall]
These users thanked the author Haans for the post (total 2): mkellyvrod (Mon Nov 03, 2014 3:14 pm) • TimAllen (Mon Nov 03, 2014 1:46 pm)
PostPosted: Mon Nov 03, 2014 11:24 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Tim, that's a great idea with the wedge. So, just to make sure I understand correctly, you have to make the fingerboard plane of the neck blank longer to allow for the wedge to be glued on. Is this right?
We are all in the gutter but some of us are looking at guitars.
PostPosted: Mon Nov 03, 2014 2:12 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
If I understand your question correctly, my answer is "yes". After making the scarf joint, I do all operations at the headstock end, volute, head plate, thicknessing, binding, etc., before attaching the heel block. By the time I'm done, the nut position is established and I can measure from there to attach the heel block. Is that what you were asking? Always a good idea to list out the various steps and their sequence so you don't suddenly find you've created a problem -- like cutting a neck blank too short.
PostPosted: Mon Nov 03, 2014 4:42 pm
First name: joseph
Last Name: sallis
Country: UK
Tim, you did understand and you've answered my question, thanks.
One more thing, was this your idea or did you take it from other sources? I'm very impressed by it.
PostPosted: Tue Nov 04, 2014 12:53 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
I don't recall getting this idea from a book, although I'd certainly seen the "look" elsewhere and wanted to recreate it. My first idea to accomplish it was to laminate a thicker headplate, but I realized that if it wasn't exactly the same thickness everywhere after glue up, I might end up with slivers of laminate under the router cut. The idea of laminating and binding a thick headplate and then gluing it as an assembly didn't appeal (although others obviously make it work). I "saw" the wedge while staring at the headplate and scarfed neck blank and figured it would be easier and less prone to screw ups. Having said that, I doubt very much it is "original" as an idea -- very few things in lutherie are truly "new". The wedge is completely hidden, so can be made out of anything. You do the final surfacing of the headstock with wedge installed on a sanding board so it is completely flat before gluing on the headplate. Then cut the headplate+wedge at the nut to achieve the thickness you want, and trim off the waste. The trickiest part of the routing for the binding is to get the depth exactly right so that the bottom cut edge intersects exactly the back corner of the nut surface (see my second picture).
I should point out that, while the fingerboard is 1/4", the binding after sanding the surface radius is somewhat less, and the binding on the headstock is a little bit less than that of the fingerboard to make it all look right. Do a mock up if you're unsure!
PostPosted: Tue Nov 04, 2014 1:16 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I you prefer peghead binding that is the same depth as the face veneer, it is much easier to bind it before installation. The same applies to fingerboard binding. Since I like to do things the easy way, that is how I have done both.
PostPosted: Tue Nov 04, 2014 4:36 pm
Last Name: Beaver
City: Lake Forest
John,
I'm thinking I'll give it a try as you describe.
Joe Beaver
Maker of Sawdust
