It is currently Sat May 02, 2026 12:26 pm
 Post subject: Re: New LMI Glue
PostPosted: Wed Nov 26, 2014 12:33 pm
Last Name: Tulloch
State: Vermont
Steve ; ......I had a bridge failure on a recent build. I can not condemn the product, and am not seeking to warn anyone off..... just my small contribution to the topic. I later tried this same bottle on a test glue up to check further and , had failure again. When the bridge / glue up failed (on the guitar) it damaged the finish also, and I was just permanently turned off to the glue. I prepared the bridge and surface, and all conditions / methods the same, but using Titebond.....and I had no problem.
I have no idea , why some have no problem at all....and some do. I've been a woodworker for 40 yrs....so I'm not clueless here.
Michael
PostPosted: Wed Nov 26, 2014 5:10 pm
First name: Peter
Last Name: Coombe
City: Bega
Zip/Postal Code: 2550
Quote:
Not sure where this "put it in the refrigerator" comes from....LMI told me they do not recommend doing this.
The fridge is for the old white glue, not the new yellow glue. It extends it's shelf life. LMI don't recommend the fridge for the new yellow glue.
Quote:
Peter and brazil66 (or anyone else) - Could you describe the failures that you had with the new glue?
I had a failure of one of the joints in the heel stack. Was carving the heel and it popped. Soon realised that the threaded insert was smack bang on the glue line.
PostPosted: Thu Nov 27, 2014 4:52 am
First name: Jay
Last Name: Gordon
City: Port Townsend
State: Washington
Zip/Postal Code: 98368
I switched over last summer. 8 guitars since then with the new glue and no problems whatsoever. Seems to set up a bit faster which is fine with me.
Jay
PostPosted: Thu Nov 27, 2014 9:26 am
First name: Yukon
Last Name: Stubblebine
City: East Boston
State: MA
Zip/Postal Code: 02128
I've just had a bridge pull up after two weeks of having been glued. I've never had a bridge come loose before with many hundreds of LMI white glue, hide glue, and titebond reglues under my belt. I am concerned.
PostPosted: Thu Dec 04, 2014 4:19 pm
Hi Everyone,
I've heard just one other similar complaint like this. After we heard it, we did more tests (the glue was tested extensively already, before we started selling it) and could not duplicate a failure. We have sold well over 1,000 bottles since we introduced the glue, so our confidence remains high. Still, if any of you would like to email me more details, we are eager to learn more.
Chris -LMI
These users thanked the author Chris -LMI for the post: Dave Rickard (Thu Dec 04, 2014 6:12 pm)
PostPosted: Thu Dec 04, 2014 11:18 pm
First name: Hugh
Last Name: Evans
I'm curious what testing has been conducted on your adhesives, and would like to see some published data. ASTM D-905 at room temp , 150F, and perhaps even 180 would be nice (to give a rough benchmark on creep performance.) Shore A hardness would back up more performance claims. To really beat stiffness testing to death, I've always wanted to run a series of laminated boards assembled used various adhesives under a 3-point load to determine the impact on modulus.
I've worked in the adhesives industry, most recently for Franklin (makers of titebond). That's one reason I enjoy the technical details.
These users thanked the author hugh.evans for the post (total 2): runamuck (Sun Dec 07, 2014 2:00 pm) • Pmaj7 (Sat Dec 06, 2014 1:50 pm)
