It is currently Fri Sep 19, 2025 11:50 am
 Post subject: Ibanez Xiphos neck
PostPosted: Fri Jan 02, 2015 3:52 pm
First name: Cecil
Last Name: Carroll
City: West Plains
State: Missouri
Zip/Postal Code: 65775
I need to remove the neck on a Xiphos. Can anyone tell me if this a set neck, through neck or whatever? I have one on my bench that is broken at the 9th fret. It seams that the brother of a gal that had been dumped by the owner of this guitar put his knee in the middle of the neck and applied great pressure to the head stock and body. The result is about 20 inches of relief at the 9th fret. How do you go about removing and replacing this neck.
Sorry for the lack of pictures but my computer has quit communicating with my camera.
cecil
 Post subject: Re: Ibanez Xiphos neck
PostPosted: Fri Jan 02, 2015 5:45 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
According to this, it's a neck through.
I have no idea how to attempt a repair.
http://ibanez.wikia.com/wiki/XPT700
I'm not a luthier.
PostPosted: Fri Jan 02, 2015 6:51 pm
Cecil - a good guitar repairman can probably glue the neck back together. I've done some jobs where the neck was in 3 pieces and the truss rod was taco'd. Won't be cheap, though....
PostPosted: Sat Jan 03, 2015 7:19 am
First name: Cecil
Last Name: Carroll
City: West Plains
State: Missouri
Thanks for the help guys. I was afraid that it was a neck through, but wasn't certain.
The owner want's to convert it to a bolt on but I am not sure that there is enough space in front of the neck pickup for the pocket.
Since the truss rod is bent about 75 degrees I will start by removing the fingerboard and the bent rod and then I can see how it will go together and how much wood is missing.
Wish me luck,
cecil
PostPosted: Sat Jan 03, 2015 9:47 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Pictures, Cecil, if you can. We'd like to see how you tackle this repair. Good luck!
Alex
