It is currently Wed Aug 06, 2025 7:16 pm
 Post subject: Oxidation on Cocobolo
PostPosted: Mon Jan 05, 2015 5:34 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I'm preparing a coco set and as I run it through the thickness sander some high spots are causing uneven oxidation removal. Does this need to be dealt with or will the finish even it out?Image
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Mon Jan 05, 2015 5:59 pm
You are likely going to sand and scrape after bending and putting the body together, so I wouldn't worry about it much ... just let the body sit around some and it will all oxidize back ... plus when you bend you will make some of the resins rise and bake on too .. that will change the colour some as well ..
PostPosted: Mon Jan 05, 2015 6:01 pm
City: Tyler
Yep, nothing to worry about.
PostPosted: Mon Jan 05, 2015 7:18 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Thanks!
Users browsing this forum: meddlingfool, peter.coombe and 41 guests
