It is currently Sun Jul 27, 2025 5:30 am
 Post subject: Cutting the neck tenon
PostPosted: Fri Feb 06, 2015 10:02 am
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, so I have the Luthier Tool neck jig, and am about to cut the tenons. I prefer the traditional tennon, no bolt ons. But this is my first time. I will practice, of course. Any bigger downside going this way ?
PostPosted: Fri Feb 06, 2015 10:58 am
First name: Tom
Last Name: West
State: Nova Scotia
Mike : Not sure what you mean by traditional with no bolts.....??
Tom
PostPosted: Fri Feb 06, 2015 11:25 am
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
If you mean cutting dovetail M/T join or that matter any of them, they all cut pretty much the same. However, on a bolt on you can do several cuts to depth, on dovetail, I went the full depth in one cut. Just different bits. There is a difference in setting the neck from dovetail and bolt on, but nothing that should cause much concern and a preference thing. I did both when I had my shop and ones worked in.
PostPosted: Fri Feb 06, 2015 12:55 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Can't I use a straight bit to do most of the cutting, then switch to dovetail bit?
PostPosted: Fri Feb 06, 2015 1:03 pm
Last Name: Beaver
City: Lake Forest
I'm not familiar with the Luthier tool jig but I would say you'll need to use the dove tail bit for all the cuts. Of course I could be wrong
Joe Beaver
Maker of Sawdust
PostPosted: Fri Feb 06, 2015 2:14 pm
I'm also not familiar with the Luthier Tool Jig but you might be able to do the body with a straight bit followed by a dove tail bit but likely not the neck. Not sure what advantage that would be. I would just follow the instructions at first till I was familiar with the jig. Mike if you want to run up to Knoxville area I'll be happy to help you practice :)
PostPosted: Fri Feb 06, 2015 4:12 pm
Mike, Robbie O'Brien has a few videos using his neck angle jig on YouTube. One covers dovetails. You watch to see how he cuts it even though your jig is different.
PostPosted: Mon Feb 09, 2015 10:09 am
That sounds like a good idea to me.
PostPosted: Tue Feb 10, 2015 12:22 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Me too. But I've never done it. And the router I bought has the HP. But still. Why would you not want to chip away at the task? Easier on the router, less chance of disaster. A straight bit would leave the stock easily shaped to final by the dovetail bit. I will explore both ideas in practice cuts
PostPosted: Tue Feb 10, 2015 7:42 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Best to hog out as much as you can with a straight bit, if possible. Dovetail bits are weak where the cutter meets the shaft, and will break pretty easily if overworked. DAMHIK. It would be good to always have a back up bit, and record your bit settings.
Alex
