It is currently Fri Jun 13, 2025 11:58 am
PostPosted: Wed Mar 04, 2015 11:28 pm
First name: Ryan
Last Name: Gallagher
City: Saint Charles
State: Illinois
Zip/Postal Code: 60174
Hi all,
I'm pretty new here and have gotten some great advice from members on a Melody Maker project. I thought it might be fun for me to share (one variation) of my process for a custom build. I'll let the pics do the talking as much as I can. Hope you guys/gals enjoy!
African Mahogany Body
Cross cutting on the old Craftsman Radial Arm
Glued up.
Nice grain pattern.
Walnut cap glued up.
Nice figuring!
Not shown, routed a channel in the mahogany for wiring, cap glued on.
Sanding and shaping the body template. Inspired by the Ibanez PF series.
Cut the body, used the radial arm as an overarm router. Not the best way (spindle too slow really) but it works. I'm doing my favorite control route: telecaster plate in back. 8-)
More routing.
Scored the recess for the metal plate.
Oops! No big deal, will still thickness sand it.
Carving the belly cut with the angle grinder and an 80 grit disc.
Worst possible way to do a switch cavity.
See what I mean! Talk about bit bite! Again, will disappear with final thickness sanding.
Time to carve the top. I like this 70s style "furniture" detail!
Grind away! This is the fun part!
On to the neck. Cut the truss rod channel. Decided on a scarf "luthier's joint" for the headstock.
Roughed in the shape on the band saw. Then attacked with the angle grinder again!
Volute for the win!
Finished roughing and routing the back. That's just a "relief" idea I had. Love the upper fret access. AND this is a 24 fret guitar, it's LONG!
Decided this would be all wood and metal, so maple inlay fret markers.
Routing the neck angle tenon. See how scientific I am about angles and stuff!
Routed for humbuckers.
Offset mortise and tenon routed.
Blending the neck joint.
My "fret press."
My trick for quickly trimming fret ends.
Almost ready to glue it all up!
Glued and waiting for finishing!
Almost final pics! I glued a walnut veneer on the headstock. I've since installed chrome hardware including covered pickups and metal rings and metal knobs as seen in the last few pics.
These users thanked the author Ryanpg for the post (total 2): Glenn_Aycock (Sun Mar 29, 2015 8:31 pm) • Cablepuller (Fri Mar 06, 2015 12:39 pm)
PostPosted: Thu Mar 05, 2015 10:00 pm
First name: Freeman
Last Name: Keller
Lots of really nice detail touches. Thanks
PostPosted: Fri Mar 06, 2015 10:00 am
First name: D
Last Name: S
Ryan,
Wow!
Very nice!
I like your design.
The fret end trimmer is a clever idea.
What finish did you use?
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Mar 06, 2015 10:55 am
I like it!
PostPosted: Fri Mar 06, 2015 12:33 pm
First name: Ryan
City: Saint Charles
State: Illinois
Thanks Dan, Chris and Freeman! Dan, it's. . . complicated. (-: the body back and sides were grain filled by French polish, then tru-oil over that, and tru-oil on the neck for a "natural feel." The walnut cap was cyanoacrylate pore filled and clear acrylic lacquer, just for extra depth and gloss.
Re: fret ends. I love to "make do" with the tools I have when I can. This method worked really great with the fretboard not attached. I adjusted my "depth" and just pushed the board back and forth. The fence made it almost error-proof. I could have gotten a nice rolled edge, or a really nice bevel if the neck were bound. Will definitely use this method again!
These users thanked the author Ryanpg for the post: dzsmith (Fri Mar 06, 2015 1:23 pm)
PostPosted: Fri Mar 06, 2015 1:59 pm
Last Name: Sollod
Ryan,
Very nicely done! What hardware (bridge) are you using?
www.swiftcreekguitars.com
PostPosted: Fri Mar 06, 2015 2:09 pm
First name: Ryan
City: Saint Charles
State: Illinois
Steve, since this build was very much an homage to 70s import guitars, I chose a harmonica style bridge (and added tusq saddles). I had to fabricate the saddle screws and nuts myself, which is why they may look a little funky. (Used brass rod, tapped on my metal lathe.)
If you would like the exact model, and where I got it, I'll have to dig through my notes - let me know!
PostPosted: Fri Mar 06, 2015 11:30 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Beauty! The walnut looks great!
Alex
PostPosted: Sat Mar 07, 2015 1:07 am
First name: Patrick
Last Name: Hanna
State: Missouri
Hey, Ryan,
I honestly don't know much about solid body guitars, but every now and then I see one that fascinates me. Yours is one that I really like. Lots of nice details and I especially like the way you chose and joined the walnut top so that the grain seems to conform to the body shape. That's pretty cool. Also, I appreciate the fact that you uploaded lots of process photos. I'm always interested in the way other people do their processes. I think you've made a very nice instrument here. Looks like your poor dog is plumb tuckered out from supervising you in the shop!
Patrick
PostPosted: Sat Mar 14, 2015 1:06 pm
State: Oregon
Nice! Great documentation.
And I'm totally stealing the fret end grinder jig! Just gotta be careful not to heat em up too much.
PostPosted: Sat Mar 14, 2015 2:58 pm
City: Escondido
Zip/Postal Code: 92029
Love the fret end dressing/beveler. What is that grinding wheel? It looks bull nosed from the picture. Is that right?
PostPosted: Sun Mar 15, 2015 10:34 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
I really like the look of the walnut cap. I hope your dog wasn't too critical of the build. He's looking at it pretty intensely out there on the deck!
PostPosted: Sun Mar 29, 2015 4:13 pm
First name: Ryan
City: Saint Charles
State: Illinois
Sorry it took SOOO long to get back to you. It's not exactly a bull nose. The tip is straight and conical. No Rounding. I think any flat edge wheel would work in this setup, just have to adjust the angle properly.
Thanks!
PostPosted: Sun Mar 29, 2015 5:01 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
My old angle grinder died. I forgot how useful they are. Need to get another one. Had a sanding disk that would chew thru wood. Nice build.
Users browsing this forum: Bing [Bot] and 3 guests
