It is currently Mon Aug 18, 2025 10:14 pm
PostPosted: Sun May 17, 2015 11:45 am
Last Name: Sollod
Does anyone know of a source of a maple neck blank that is 3"x4" that I can cut out 2 necks from? I can find vendors that sell 1"x4" boards, but I think I would rather have a solid neck or at least laminated...
www.swiftcreekguitars.com
PostPosted: Sun May 17, 2015 12:23 pm
I use turning "spindle blanks" they can range from 1 1/2" to 4" even 6" at times, often they are perfectly 1/4 sawn. Most reputable hardwood suppliers should have them.
Ken Cierp
PostPosted: Sun May 17, 2015 2:32 pm
Try Jerry at American Specialty Hardwoods. He will probably get you whatever size you need.
PostPosted: Sun May 17, 2015 2:43 pm
Get 3 of the 1" boards, turn them up on edge, and laminate.
PostPosted: Mon May 18, 2015 6:51 am
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
You do realize that the short grain in one-piece necks makes the headstock more prone to breaking, right? This is a very common problem in Gibsons (and others), especially with high tension (electric and steel) strings.
The laminated scarf joint is significantly stronger and fairly easy to do.
Good luck,
Glenn
These users thanked the author Glenn_Aycock for the post: ernie (Mon May 18, 2015 7:14 am)
 Post subject: Re: Source of 3
PostPosted: Mon May 18, 2015 10:08 am
Good luck,
Glenn
Not as much of an issue if the truss rod adjustment is not in the headstock.
These users thanked the author SteveSmith for the post: kencierp (Mon May 18, 2015 10:26 am)
PostPosted: Wed May 20, 2015 6:49 am
First name: Glenn
Last Name: Aycock
City: El Lago
Less so in maple too, I would imagine?
PostPosted: Thu May 21, 2015 6:59 pm
First name: Al
Last Name: Peebels
City: Johnston City
State: Il
Zip/Postal Code: 62951
Hibdon had some the last time i was there.
PostPosted: Thu May 21, 2015 7:34 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Steve,
I'll offer my opinion that you should do EXACTLY what Barry Daniels advised you to do. I have read your post that you don't think the short grain through the neck-headstock area is much of an issue if you have your truss rod adjustment end reversed. I personally think you are mistaken about that. Short grain is short grain. Even with side wings and top and back plates to reinforce this area, it is still vulnerable to breaks. But I know your opinion is formed and firm in your mind. You can make two necks out of the blank you propose and, if you are very careful with them, they will both outlive you. But you could be a might safer doing what Barry recommended, then gluing on side wings, and then gluing on top and back plates. Even if you do what Barry and I do, that area will always be vulnerable.
PostPosted: Sun May 24, 2015 5:36 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
" The Woodwell" for all your maple needs. I have been getting great maple from them for several years.
Users browsing this forum: Bing [Bot], TimAllen and 33 guests
