It is currently Fri Aug 15, 2025 5:51 pm
 Post subject: register pins
PostPosted: Tue May 26, 2015 10:14 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I am putting on a top and a back. I have used barbecue skewers (1/8") to register the top by going into the neck block under the fretboard and into the heel block so the hole in the top is within the purfling.
I am not putting purfling on the back of this one - is there a way to use register pins for the back??
Ed
 Post subject: Re: register pins
PostPosted: Tue May 26, 2015 10:16 am
I leave a excess tab on the plates, drill the pin holes into that and register them into my mold.
PostPosted: Tue May 26, 2015 1:16 pm
I've left a tab on the plates both end (you can offset them from the center line) and used Hide Glue to attach a small blocks to the body so pins can be registered into them.
Just saw off the excess before trimming and use a chisel to remove the blocks down to just above the glue line.
Then hot water takes the last traces off.
You can also register small pins into the binding area, it's removed anyway, but I'm not brave enough for that.
PostPosted: Tue May 26, 2015 1:49 pm
I favor though brace ends top and back -- I found that when notches are done precisely the top and back are pretty much locked in place. If width-wise adjustment is necessary I use binding tape to keep the center-lines mated.
Ken Cierp
PostPosted: Tue May 26, 2015 6:28 pm
First name: Alan
Last Name: Jones
City: Cobble Hill
State: British Columbia
I'm with Ken on this one......my bracing notches are what I use for lining up tops and backs for gluing as well.
Blue Ring Acoustics
blueringacoustics.ca
PostPosted: Wed May 27, 2015 6:12 am
Last Name: Minch
City: Chestertown
That's how I have been doing it on the few I have built, so I guess I keep on keepin' on.
Ed
Users browsing this forum: Michaeldc, Mike Thomas and 7 guests
