It is currently Fri Sep 19, 2025 3:58 pm
PostPosted: Fri Feb 27, 2015 6:48 pm
First name: D
Last Name: S
I ordered the set on the right because it looked too cool to pass up.
Plan to use it as a top.
Anyone have experience using it?
Not sure what to expect.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Feb 27, 2015 6:54 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Expect it to smell really good!
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
These users thanked the author A.Hix for the post: dzsmith (Fri Feb 27, 2015 7:13 pm)
PostPosted: Fri Feb 27, 2015 7:46 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Do you have plans for that set, Dan, or did you just had to have it, and figure it out later? Looks really nice!
Alex
PostPosted: Fri Feb 27, 2015 8:16 pm
First name: D
Last Name: S
Alex,
Yeah, I buy the wood first and then figure out what to do with it.
It was new at Gilmer, so I jumped on it. Each piece is one inch thick, so I can make a top and back set.
Or, matching Tele and LP.
Who knows?
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Apr 12, 2015 10:37 am
First name: D
Last Name: S
This stuff must be green. Continous warping. I put the pieces between sticks and weighted them down.
I'm afraid to use it in the current state.
Oh well, I boight some figured Maple and Walnut to keep me busy.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Apr 12, 2015 12:26 pm
First name: Ringo
Wild grain stuff like what you have is going to want to move quite a bit as it dries and will likely crack a lot as well if it is to stay relatively flat. If it's green you're going to want to use a LOT of weight on the stickered pile... a lot more than you probably think. You might also consider using ratcheting tie down straps in a similar arrangement to this:
These exert a lot of force on the stack and keep everything relatively compact. As it dries and shrinks every so often you can ratchet the straps to get them tight again and keep constant pressure on the set.
These users thanked the author James Ringelspaugh for the post: Alex Kleon (Mon Apr 13, 2015 3:24 pm)
PostPosted: Sun Apr 12, 2015 4:09 pm
First name: D
Last Name: S
Thanks James,
I have about 10 pounds on it, it has assumed a flat shape.
I'll goose it up with more weight.
Dan
That look's like Perssimon you are drying. If so, I read it's a rascal to dry.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Apr 12, 2015 6:38 pm
First name: Ringo
It's actually black and white ebony, which compared to drying persimmon is a walk in the park. I've never seen green wood misbehave like this stuff, thus the heavy duty strapping.
These users thanked the author James Ringelspaugh for the post (total 2): Alex Kleon (Mon Apr 13, 2015 3:23 pm) • dzsmith (Sun Apr 12, 2015 7:29 pm)
PostPosted: Fri Jun 05, 2015 7:07 pm
Camphor burl, It took about a year for mine from gilmer to dry properly. It will lose all of its color by that time. Camphor has a lot of oil in it and finishing it can be a pain in the butt. Be ready to sand and glue at the same time. Also sand then spray dewaxed shellac as a sealer when it comes time to finish. This guitar has a 1/4" book matched top, stained with very dark red after the shellac sealer, sanded back, resealed shellac, then clear coat lacquer with red tint, black burst, then final clear coats. Picture does not do it justice, it's really more of a red wine color and the dark spots are closer to heavy deep burgundy.
Just my 0.02cents
mk
I'm outside looking in, just farther from the window than most.
PostPosted: Fri Jun 05, 2015 8:54 pm
First name: D
Last Name: S
Thanks Mike!
Great looking guitar!
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jun 05, 2015 9:19 pm
First name: Jeff
Last Name: Dillard
Like the wood Dan.man that's pretty. Love the guitar Mike.
These users thanked the author Jfurry for the post: dzsmith (Sat Jun 06, 2015 11:08 am)
