It is currently Sat Aug 02, 2025 12:58 am
PostPosted: Wed Jul 08, 2015 11:19 pm
First name: Raymond
Last Name: Pipkin
I figure this subject is not a big deal in the scheme of things and suspect purely cosmetic, but for those using reverse kerfed linings, I've found it somewhat more difficult to hide breaks in the linings than on the standard kerfed since the web is outward facing in the box. I can make the transition look good but still noticeable to me, from one piece of lining to the next.
I like the other aspects of reverse kerf linings, but also like using different length scraps to make the linings and reduce waste which mean that the linings stop an start at random positions on the sides.
Any thoughts or tips on that to make the inside of the box look cleaner? Or should,I simply be looking at making that transition cleaner in the first place?
PostPosted: Thu Jul 09, 2015 12:45 am
First name: Heath
Last Name: Blair
City: Visalia
I thought it was silly at first to pre-bend something so bendable, but I stick my reverse kerf linings in the Fox bender before installing them. Now I don't have any breaks.
sweat the small stuff.
These users thanked the author Heath Blair for the post: rtpipkin (Thu Jul 09, 2015 10:28 pm)
PostPosted: Thu Jul 09, 2015 6:40 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I won't use a broken piece of reversed lining. I agree, it's hard to make it look clean. It could just be me, but the regular lining always seemed more flexible. Certainly, it's more repairable.
These users thanked the author Mike OMelia for the post: rtpipkin (Thu Jul 09, 2015 10:29 pm)
PostPosted: Thu Jul 09, 2015 7:50 am
This is how I prep the RR
http://www.kennethmichaelguitars.com/RE ... RFING.html
Ken Cierp
These users thanked the author kencierp for the post (total 2): rtpipkin (Thu Jul 09, 2015 10:26 pm) • mkellyvrod (Thu Jul 09, 2015 1:21 pm)
PostPosted: Thu Jul 09, 2015 8:10 am
kencierp wrote:
Wow that is an interesting test you did. I had no idea that it stiffened up the sides by that much. I guess I'll stick to the solid linings I like to use :D
Brilliant idea on how to bend them perfectly too! [:Y:]
Could you also just cut the kerf deeper too? I know that is kind of a PIA if you buy them precut.
PostPosted: Thu Jul 09, 2015 9:02 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I suppose you could glue a strip of veneer the full length of the linings after they are in to reinforce the breaks/gaps and tie it all together back into a solid piece. That would recapture the stiffness of reversed kerf linings. You could also dress it up with a contrasting veneer or one that matches the side wood. All that said, I don't think I would bother unless there were several breaks visible through the soundhole.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: rtpipkin (Thu Jul 09, 2015 10:29 pm)
PostPosted: Thu Jul 09, 2015 9:11 am
I've been a fan of RK linings too and used them on very nearly every guitar that I ever built.
I'll also second Ken's excellent toot about just how stiff these linings are AND how stiff they make the rim. Once my RK linings were on the rim could come out of the mold as Ken said.
When using more than one piece to wrap the rim I would plan my joins to be on the fairly flat section where the waist transitions to the lower bout. I also would use a small miter box and a Zona saw and cut the two mating pieces at 45 degree angles and butt them together. SInce the rim is close to flat in this location it always worked very well for me.
Also I picked up one of those plastic trays for wall paper and to make them more flexible I would soak them in very hot water for about 60 seconds, pad the excess water off and then they were always ready to bend and glue. I learned the soaking trick from Lance and it works great.
These users thanked the author Hesh for the post: rtpipkin (Thu Jul 09, 2015 10:28 pm)
PostPosted: Thu Jul 09, 2015 9:36 am
Last Name: Colbert
City: Anacortes
A bit off topic... Do you guys have any tricks for applying glue to RK?
PostPosted: Thu Jul 09, 2015 9:49 am
I have these at all the gluing operations, I usually work from a little puddle of adhesive on a piece of cardboard. You don't have to clean them like a brush, let the glue dry and it peels right off -- works for me.
http://www.woodcraft.com/Product/147917 ... piece.aspx
Ken Cierp
These users thanked the author kencierp for the post: Michaeldc (Thu Jul 09, 2015 2:50 pm)
PostPosted: Thu Jul 09, 2015 9:52 am
I do a dry clamp and then run masking tape under the lining. Glue goes on in the normal way (I use brush and finger). After clamping I use a straw cut at an angle to get most of the squeeze out then clean up with a damp rag. Finally I remove the tape before I set it aside to dry.
Edit after seeing Ken's post. I use a lot of spreaders too, mine are homemade from credit card samples. The brushes I use are acid brushes - I trim and recrimp them so they don't lose hairs in the glue and then normally toss them when done.
These users thanked the author SteveSmith for the post: rtpipkin (Thu Jul 09, 2015 10:29 pm)
PostPosted: Thu Jul 09, 2015 11:06 am
First name: Danny
Last Name: Vincent
I make my own RK lining. After struggling with breaks, which don't look very professional, I now make them heavy enough that they require a Fox Bender to bend them.
Makes for a very stiff rim. I think that's good, right?
These users thanked the author DannyV for the post: rtpipkin (Thu Jul 09, 2015 10:29 pm)
PostPosted: Thu Jul 09, 2015 12:14 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
How do you deal with or prevent glue ending up in the kerfs?
Personally, I prefer the look of the non-reverse linings, but the added rigidity of the RK linings is attractive.
PostPosted: Thu Jul 09, 2015 1:00 pm
With our (KMG) thin micro kerf RR linings some segment bonding is expected and I think it may add some strength to the assembly. As for appearance -- I've never had a glue mess issue, thin layer on the lining, thin layer on the side. I draw a guide line on the side shy of the lining height.
Ken Cierp
These users thanked the author kencierp for the post: J De Rocher (Thu Jul 09, 2015 1:49 pm)
PostPosted: Thu Jul 09, 2015 1:42 pm
J De Rocher wrote:
How do you deal with or prevent glue ending up in the kerfs? ...
As Ken alluded, it's a matter of technique - a thin layer on the linings and a thin layer on the sides.
These users thanked the author SteveSmith for the post: J De Rocher (Thu Jul 09, 2015 1:50 pm)
PostPosted: Thu Jul 09, 2015 3:53 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I thought I might just add what the reason is for Ken's technique of shaping them on the -outside- of the guitar. By using the outside as a form you get the benefit of it supporting the "skin" holding the blocks together, so it won't buckle or break. I'm impressed how well the kerfed lining holds its shape after it dries, and broken section just don't happen to me since I started using that method,
These users thanked the author Imbler for the post: rtpipkin (Thu Jul 09, 2015 10:33 pm)
PostPosted: Thu Jul 09, 2015 10:41 pm
First name: Raymond
Last Name: Pipkin
Thanks everyone! All great ideas, even the off topic as I've wondered about those as well.
PostPosted: Fri Jul 10, 2015 9:03 pm
When I make reverse kerfed linings I sometimes run a decorative edge on the unkerfed sticks- fillet and roundover or fillet and ogee which reduces the amount of "web" area holding the segments together. After kerfing the sticks I run them through the drum sander and reduce the depth of the fillet to make the pieces more bendable.
These users thanked the author Clay S. for the post: rtpipkin (Sat Jul 11, 2015 12:54 am)
