It is currently Tue Aug 19, 2025 2:07 am
PostPosted: Wed Oct 21, 2015 5:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Can someone suggest a polishing compound safe for Varnish (Enduro-Var). I want to test some ideas. I have the McGuires Swirl remover, but it never seems very effective to me. Maybe I'm using it wrong...
(I apply, and use a cotton mushroom pad to work it)
PostPosted: Thu Oct 22, 2015 5:16 am
Mike what's your objective a very high shine or removing swirl and/or fine scratches?
McGuires also makes a fine cut cleaner that is slightly more aggressive than the swirl remover and yes you are using it as I would.
Recently we tried some of the polishes that Jescar is selling on their consumer web site and we liked them a lot - more than McGuires.
Take any of this with a grain of salt, you qualified, rightly your question with the mention of Enduro-var which is something that I doubt that we've ever encountered before so we can't know in the case of Enduro.
PostPosted: Thu Oct 22, 2015 6:45 am
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
Mike,
In my experience, compounding by hand isn't very effective on most surfaces, especially if you are trying to get a mirror shine. I use the foam pads that you chuck in a power drill (available at most auto parts stores). I think stewmac sells them too, which is where I got the idea 25 years ago.
God luck.
Glenn
PostPosted: Thu Oct 22, 2015 7:01 am
I don't know about Endurovar but I've had the best luck by wet sanding with Micro Mesh to 6000 then polishing by hand with Novus #1. This is on Royal Lac.
PostPosted: Thu Oct 22, 2015 7:28 am
We use the Wizard's product line.
Ken Cierp
