It is currently Thu Aug 21, 2025 4:04 am
PostPosted: Thu Nov 05, 2015 3:29 pm
Hey fellas
Another question: I have done a fair bit of reading and researching (and head scratching) trying to find a reliable method for tracing an arc for, say, a circle of 60ft radius, other than physically making a 60ft long piece of wood on a pivot with a pencil at the end.
Do you use a mathematical formula to be able to find the amount of vertical deflection to use for a given length of a flexible piece of plastic or metal with a nail at each end and one in the middle, as outlined in Cumpiano's book? For instance, if my piece is 12 inches long and I want a 60ft radius arc, how much to I need to raise the middle nail so that I get the proper arc?
Comments and suggestions greatly appreciated!
PostPosted: Thu Nov 05, 2015 3:36 pm
This may help
http://www.liutaiomottola.com/formulae/sag.htm
Ken Cierp
PostPosted: Thu Nov 05, 2015 3:49 pm
YES!
Thank you!!
PostPosted: Thu Nov 05, 2015 4:28 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
a very accurate way is to use a shipwright compass. You can use it in combination with the formula for a sagitta. Here is a post for the down under forum describing its use. http://www.anzlf.com/viewtopic.php?p=70212#p70212
PostPosted: Thu Nov 05, 2015 4:59 pm
And remember if you actually hit 58 foot or 62 foot it really is not going to make a big difference.
PostPosted: Thu Nov 05, 2015 7:33 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
I use a CAD program. I draw a 60' radius circle, then trim the part I want to use, then print it out.
Users browsing this forum: Bing [Bot] and 8 guests
