It is currently Fri May 15, 2026 5:04 am
 Post subject: Zebrawood Bridge
PostPosted: Wed Dec 16, 2015 5:22 pm
First name: Brad
Last Name: Combs
Hello,
I'm in the process of building my first guitar. The B&S are Zebrawood. I also made the rosette and soundhole binding out of zebrawood. The headstock will have a zebrawood veneer.
Would it make sense to have a zebrawood bridge? Any pitfalls to using this wood as bridge material?
Does the bridge need to be 90 to the top grain? If so, a zebrawood bridge might look strange.
Your ideas are appreciated.
Thanks!
Brad
 Post subject: Re: Zebrawood Bridge
PostPosted: Wed Dec 16, 2015 6:35 pm
Yep, 90 degree grain direction is a must for a bridge.
These users thanked the author Barry Daniels for the post: bcombs510 (Wed Dec 16, 2015 8:45 pm)
PostPosted: Wed Dec 16, 2015 8:45 pm
First name: Brad
Last Name: Combs
Thanks! Ebony it is!
PostPosted: Wed Dec 16, 2015 10:21 pm
First name: Alan
Last Name: Jones
City: Cobble Hill
State: British Columbia
Here is a pic of a zebrawood bridge on a dread ready to go to finish. Sorry the pic isn't a closeup but I wasn't
documenting just the bridge. It looks just fine on the Englemann top.( also a zebra fretboard)
Blue Ring Acoustics
blueringacoustics.ca
PostPosted: Thu Dec 17, 2015 12:35 am
First name: Danny
Last Name: Vincent
Um. I think there might be a bit of discussion on this point Barry. Some schools feel that somewhat riff sawn might be less prone to crack however it escapes me which direction the grain should run. I think the best bet to eliminate a cracked bridge would be the Trevor Gore approach. Laminate a layer of CF in the middle. Zebrawood might make a perfectly acceptable bridge. I've never made one myself and it might be on the lighter side but easy enough to add a little mass.
PostPosted: Thu Dec 17, 2015 2:41 am
Um.
I think he meant side to side, not up and down (quartersawn)
PostPosted: Thu Dec 17, 2015 8:34 am
First name: Brad
Last Name: Combs
Sorry, I'm not sure that I'm following. Are you saying that a piece of zebrawood laminated with ebony (for example) in the middle would work as long as the ebony grain is indeed running 90 to the top grain?
PostPosted: Thu Dec 17, 2015 9:25 am
First name: Danny
Last Name: Vincent
Um.
Hey your right Colin. I would have thought that to be a given.
What Barry said. Under no circumstances would you want the grain of the bridge to run parallel to the top grain.
PostPosted: Thu Dec 17, 2015 2:30 pm
First name: Brad
Last Name: Combs
Perfect. Thanks!
Users browsing this forum: No registered users and 98 guests
