It is currently Fri May 15, 2026 12:37 am
 Post subject: Old truss rod
PostPosted: Sat Dec 19, 2015 9:51 am
First name: Brad
Last Name: Combs
Hello,
I have this older truss rod pictured below. It is a bit wider than the 1/4" one that I have from LMI. It's closer to 7/16. In the pic you can see a black thin cardboard strip that is taped in place with masking tape. I presume this was so it wouldn't be lost by the guy that had this before me. :) On the side that is facing into the neck there is masking tape covering the channel. The rod in the channel has strips if masking tape around it as well. I was planning to peel all of this off and then thought maybe that is the design? The tape keeps vibration from happening or something?
For anyone that has used this type or knows the answer, some questions:
1) Should I take the tape off the black strip before installation?
2) Should I take the tape off that is covering the channel?
3) Should I take the wrapped tape off the rod?
Thanks!
Brad
 Post subject: Re: Old truss rod
PostPosted: Sat Dec 19, 2015 10:33 am
First name: Tom
Last Name: West
State: Nova Scotia
Brad: That looks like the aluminum channel Martin style for sale by Stew-Mac. The black may be fiber that was to be installed in a too wide channel..??? It can come off. The tape covering the channel stays on and I am unsure about anything on the rod because I've never opened the channel of this type of rod. They are an excellent rod but are one way and one has to be aware of that fact. I use them and epoxy them into the channel in the neck which adds to neck stiffness. All that has been said above is in relation to the Stew-Mac rods.
Tom
These users thanked the author Tom West for the post: bcombs510 (Sat Dec 19, 2015 12:28 pm)
PostPosted: Sat Dec 19, 2015 10:48 am
Your pictures are not very clear -- but the Martin protocol is to have the slot slightly deeper than the aluminum rod itself. The tape on the open side of the rod is to prevent glue from getting on the mechanism (threads) do not remove. The black strip is a filler that goes between the top of the rod and the fingerboard. Assembled as seen here:
http://www.kennethmichaelguitars.com/ne ... embly.html
Ken Cierp
These users thanked the author kencierp for the post: bcombs510 (Sat Dec 19, 2015 12:28 pm)
PostPosted: Sat Dec 19, 2015 12:29 pm
First name: Brad
Last Name: Combs
Thanks, Tom and Ken. I'll give it a shot with these. I had it so I figured I would use it instead of buying another two way.
PostPosted: Sat Dec 19, 2015 3:42 pm
First name: Tom
Last Name: West
State: Nova Scotia
Ken: Very good. Slow me never even thought of that..!
Tom
Users browsing this forum: No registered users and 110 guests
