It is currently Mon Aug 18, 2025 1:34 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 28, 2006 3:15 pm
James, I hope that was an Ovation
PostPosted: Tue Feb 28, 2006 4:38 pm
Scary...
PostPosted: Tue Feb 28, 2006 9:42 pm
I'll go back to using the broad axe for this task, it looks to deliver a wee bit more finesse
PostPosted: Tue Feb 28, 2006 9:47 pm
No, it wasn't an Ovation. Just my warped sense of humor.    This is one of my early ones that I am re-topping. Since I wasn't trying to save any part of the old top, I was using the quick method of removal. This thread was going on, and my mind just couldn't stop thinking up the questions.    I figured it would make a funny picture to start in the bridge pin hole. No, I didn't want that bridge....... stock replacement, drop in saddle, EI RW. Now I'm sure I won't have a weak moment and try it on another guitar.
I have actually used the jigsaw method for slotting. No problems. I'm relieved to see that Mario and Sylvan also use it. I thought I was being weird. I also have the little slotting saw, but it is harder to get the slot straight with that than with the jigsaw.
PostPosted: Tue Feb 28, 2006 9:50 pm
James,
So it was a scene from "The Texas Jigsaw Massacre" then
PostPosted: Wed Mar 01, 2006 2:35 am
BTW, a good jig saw is an extremely useful tool for all kinds of things. If you want to invest in a good one, I'd suggest getting a Bosch. They are widely regarded as the best. It'd be money well spent.
Todd Rose
Ithaca, NY
PostPosted: Fri Mar 03, 2006 7:33 am
I just set up a guitar so I took some photos of slotting the bridge with my
jigsaw. See, I really do do it with the saw!
Sylvan
http://www.wellsguitars.com
PostPosted: Fri Mar 03, 2006 7:38 am
TJk if that thing had a rosewood handel I would swear you stold it from my shop... The funny thing is my has come up missing
PostPosted: Fri Mar 03, 2006 9:36 am
I just know I would saw the guitar in half
What sort of blade do you use Sylvan ?
PostPosted: Fri Mar 03, 2006 2:41 pm
Russell -
It was just an ordinary jig saw blade that I grinded down to a size that would
fit a 3/16" hole. Its' thickness is about the thickness of a big "E" string. I
have never measured it but the blades' importance is that it fit inside the
hole so you can start the saw in a straight line. It is very controllable and
reliable - as scary as it looks!
Sylvan
PostPosted: Fri Mar 03, 2006 3:13 pm
Jigsaw for me too. I have a piece of padded vinyl flooring cut the the shape of the top with a precise hole cut out for the bridge. Put the linoleum on the top to protect the precious finish and then you have much less worrys about using a power tool.
tim...
PostPosted: Fri Mar 03, 2006 4:41 pm
I am going to give this a try, thanks to all for the info!
PostPosted: Sat Mar 04, 2006 2:12 pm
Thanks Sylvan
