It is currently Sun May 17, 2026 6:20 am
PostPosted: Tue Jan 19, 2016 6:42 pm
Last Name: Sollod
What is your philosophy regarding whether the upper tone bar should or should not touch the bridge plate? It seems that some do... and some don't... I do. Should I reconsider?
www.swiftcreekguitars.com
PostPosted: Tue Jan 19, 2016 9:05 pm
My brace layout is slightly different than most. I place my upper tone bar so it butts up to the bridge plate almost at the centre of the bridge plate, and actually I couple all the braces to each other by butting to one of the braces.
I think it important that the whole top work together and by not coupling each brace to the next there is a disconnect between everything that produces sound from the top.
As to your specific question, I do couple the upper tone bar to the bridge plate...as mentioned.
PostPosted: Tue Jan 19, 2016 11:30 pm
I don't doubt that Rod has great results with his bracing formula. I've had extremely positive results from this pattern, a variation on the system developed by my teacher and former employer. In this case it's for my OM model. As you can see, I'm a non-tucker. And a non-scalloper. Of course, I adjust the bracing height & location depending on the body size and whether it's a 6 or 12.
michael propsom
www.propsomguitars.com
These users thanked the author jsmith for the post: Robbie_McD (Wed Jan 20, 2016 8:48 am)
PostPosted: Tue Jan 19, 2016 11:33 pm
I would say he gets GREAT results!
PostPosted: Wed Jan 20, 2016 2:19 am
You guys are too kind, but I'm just a noob in the craft with only 12 guitars under my belt.
This is my latest bracing patter which I've done with about 50% of my guitars. I've tried the Somogyi double x thing as well as the tapered vs scalloped thing....my best sounds (subjective to my ears) has been this one here.
I'll even give the profile pics.
PostPosted: Wed Jan 20, 2016 2:23 am
Gorgeous top, Rod. And something tells me that went on a cutaway.
michael propsom
PostPosted: Wed Jan 20, 2016 2:28 am
Michael, that looks a bit like the Lowden bracing style....?
And nice looking top. Cedar or redwood?
PostPosted: Wed Jan 20, 2016 3:04 am
Yes, that was on a cutaway :)
Upper most Transverse gave that away I'm sure.
Users browsing this forum: Facebook [Bot] and 68 guests
