It is currently Sat Jun 13, 2026 3:44 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Tue Feb 09, 2016 9:59 am
First name: Craig
Last Name: Bumgarner
City: Drayden
Beautiful work! Love the look of the top. I noted you used a clear UV cured pore fill. Would you mind disclosing the product. Simtec 59x1? By the looks, it works very well.
Craig Bumgarner
Bumgarner Guitar Blog
PostPosted: Tue Feb 09, 2016 11:39 am
Last Name: Alvarado
City: Santa Rosa Beach
State: FL
Zip/Postal Code: 32439
Craig,
I'm using the Cure UV gel poor fill with one of there old UV lamp systems. I got an entire UV cure system on eBay, for $400 and it came with the poor fill, sealer, and topcoat. After trying the entire system on several test pieces, I hated the way it looked and sprayed. I've been spraying lacquer for about 15 years and it just felt and looked like plastic to me. I pot the entire system on the shelf for about two years and forgot about it. Then , about four guitars ago, it occurred to me that the poor fill portion of the system may be useful because it's easy to apply, hard as a rock, crystal clear, and cures in 15 seconds. I've been spraying a wash coat of lacquer on the bare wood as to seal it, then applying and leveling three light layers of poor fill. The entire process of poor fill takes about an hour and I'm on to spraying my final lacquer coats. If you can find a good deal on a UV system, it's the way to go!
http://www.cureuv.com/uv-cure-wipe-on-g ... quart.html
As for the tone of the guitar, I'd say it's on par with my best sounding guitar. (And that includes several BRW and ABW guitars). It has a very broken in sound right out of the gate, and a ton of volume. Very punchy yet responds great to a delicate touch. I'd say that the Brazilian and Cedar guitar I build several years ago has a better low E string warmth, but the Torrified top has a lot more volume and projection, while still remaining warm and not too harsh.
Chris Alvarado
www.ChrisAlvaradoLive.com
www.Driftwood-Guitars.com
PostPosted: Tue Feb 09, 2016 11:55 am
First name: Craig
City: Drayden
Thanks for the details Chris, I'll definitely look into it. I use epoxy, which works well, but takes a day per fill and typically three fills. This represents a pretty significant amount of time in my build calendar. One hour sounds way better.
One question is how does the Cure UV Pore Filler blend in if broken through in sanding? With epoxy, I sand the first two coats aggressively and usually break through, but the next coat blends right in. I trowel two coats, sand well and then wipe the third coat with alcohol for a smooth surface that requires little sanding. Works well, BUT, it takes 3 days!
Would be interested in what lamp you are using. I looked at the CureUV site and the lamps look outta sight expensive. Cheapest one so far is $3,500. Could not find anything on eBay like the kit you found.
Craig Bumgarner
PostPosted: Tue Feb 09, 2016 12:52 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Wow...that's gorgeous. I like that sunburst on the neck...nice detail
Nice photos too...really brings out the deep gloss finish
PostPosted: Tue Feb 09, 2016 5:35 pm
Last Name: Alvarado
State: FL
I find that the Uv poor fill works and blends almost exactly like Z Poxy. The last coat takes care of any burn through so and blends perfectly. Yeah the lights are expensive, but a good deal can be had from time to time on eBay. That's why pounced on the $400 deal I found on eBay years ago.
Chris Alvarado
PostPosted: Tue Feb 09, 2016 7:29 pm
Last Name: Alvarado
State: FL
Here's a UV light setup like mine for $950!
http://www.ebay.com/ulk/itm/321995829149
Chris Alvarado
PostPosted: Tue Feb 09, 2016 7:50 pm
Lovely Chris! Very Classy.
PostPosted: Tue Feb 09, 2016 7:54 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I was gonna ask about your pics too. They look professional. Nice! I wish I could take pics like that.
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
PostPosted: Wed Feb 10, 2016 7:25 pm
Wow! That is stunning in all regards. I love the end graft overlapping on the back. Very nice touch. The finish is spectacular and I love the burst on the neck too.
PostPosted: Wed Feb 10, 2016 9:42 pm
Gorgeous guitar. I love that end graft detail.
PostPosted: Fri Feb 12, 2016 10:26 pm
Why am I just looking at this now??!! That's a beauty Chris!
PostPosted: Sat Feb 13, 2016 5:45 pm
Fantastic looking guitar... love the snake wood under that finish.. hope mine look like that one day!!
PostPosted: Sun Feb 14, 2016 2:52 pm
First name: Buzz
Last Name: Roberts
City: Crystal Beach
State: ON
Zip/Postal Code: L0S 1B0
Very nice job indeed.
The long way around is often the fastest way there.
PostPosted: Sun Feb 14, 2016 4:25 pm
Kudos! It's a really nice guitar!
I love the finish!
PostPosted: Wed Feb 17, 2016 6:39 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
Very nice.
Did you use Stewmac's torrefied Sitka spruce brace stock as well?
I'm on my second torrefied top guitar and I'm really looking forward to hearing how it sounds. The first one was very impressive. (Stewmac torrefied Sitka top and brace wood)
Users browsing this forum: Bing [Bot] and 44 guests
