It is currently Fri Aug 01, 2025 8:42 am
 Post subject: Archtop pickup
PostPosted: Mon Feb 22, 2016 12:58 am
First name: herry
Last Name: trismono
City: malang
State: east java
Zip/Postal Code: 65142
Country: Indonesia
Hi.
I want to know what You use the pickup of your Archtop guitar?
I have not built archtop guitar yet, and I will build soon. so I need your suggestion for the pickup..
When I saw the floating pickup and fix pickup or piezo undersaddle pickup?
I confuse for that. So I need your help please.
thank you so much. duh [uncle] [uncle] [uncle]
 Post subject: Re: Archtop pickup
PostPosted: Mon Feb 22, 2016 9:57 am
First name: Rob
Last Name: Roither
City: Williamsburg
Zip/Postal Code: 23188
Hi Herry,
I use a Benedetto S6 which mounts to the underside of the pickguard and floats slightly above the body at the end of the fretboard.
PostPosted: Mon Feb 22, 2016 10:44 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I had a Jimmy Smith floating pick up that mounted to the end of the fretboard
that I liked.
You could use both types,
and go stereo!
PostPosted: Mon Feb 22, 2016 11:28 am
I made one with a Fishman archtop bridge with a built-in piezo pickup, and this was blended with a fretboard suspended humbucker. The preamp circuit that I built was mounted under the pick guard with slider switches and watch batteries. The design for the circuit is over on the MIMF.
PostPosted: Mon Feb 22, 2016 2:32 pm
For jazz guitar the Kent Armstrong PAF hand wound 12 pole humbucker is my favorite. Floating or mounted.
https://www.archtop.com/ac_access.html
PostPosted: Mon Feb 22, 2016 3:59 pm
Hard to go wrong with Bill Lawrence's classic A-400.
Came out in the 70's, and still sounding sweet and articulate!
Affordable, too.
PostPosted: Thu Feb 25, 2016 12:15 am
City: Escondido
Zip/Postal Code: 92029
It depends a lot on the guitar you are putting it on. Carved spruce top? Carved maple? Laminate?
I second the Armstrong hand wound 12 pole if you have an acoustic spruce top and you don't want to cut into it. A laminate top guitar is basically an electric instrument. Cut into it and mount whatever you like. Seth Lover's for eg. If you have a thin bent top like an old Selmer you may want a hexaphonic six string piezo.
PostPosted: Thu Feb 25, 2016 9:19 am
Midi synthesizer pick up?
Ken Cierp
PostPosted: Thu Feb 25, 2016 9:03 pm
City: Escondido
Yeah, like these guys:
http://www.rmcpickup.com
Doesn't have to be midi, they can just output to line. Nice if you are using nylon strings or something other than nickel.
PostPosted: Fri Feb 26, 2016 1:21 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Affordable, too.
Thank's Chris. maybe this is my fisrt choice and so about the price thank's
PostPosted: Fri Feb 26, 2016 1:35 am
First name: herry
Last Name: trismono
City: malang
State: east java
Country: Indonesia
Thank's Rirhett. I will build carved spruce top ( I had two years ago from Alaska Specialty Woods) and Back & Side set (big leaf) Mahogany from my local area. all wood quarter sawn. What do you think if I use Bill Lawrence A400, consider with money I plan, another choice piezo pickup undersaddle built by Cafewalter. thank's I need your opinion. bliss
