It is currently Fri Apr 17, 2026 2:33 pm
 Post subject: string height?
PostPosted: Sat Mar 05, 2016 12:00 pm
My first ukulele is a soprano. What height should I shoot for above the 12th fret?
 Post subject: Re: string height?
PostPosted: Sat Mar 05, 2016 12:55 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
3 mm, with enough saddle to take it down to 2.5 mm.
Roughly speaking, on a soprano 3 mm suits strummers, 2.5 mm is for those who like to fingerpick as well. 2mm is for really flashy fingerpickers, but is hard to achieve without buzz and I wouldn't try it on a first build.
These users thanked the author profchris for the post: wbergman (Sat Mar 05, 2016 4:48 pm)
PostPosted: Sat Mar 05, 2016 4:48 pm
By the way, the plan I have uses a string spacing of 9/16", which is way more than classicals. Is that OK?
PostPosted: Sun Mar 06, 2016 6:15 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
9/16 reads like a misprint, wherever you're measuring it.
I use 9mm at the nut, 13mm at the saddle, which is close to "standard" (i.e. what Martin used in the 20s, though I'm sure they measured in inches).
That's roughly 11/32 at the nut, 1/2 at the saddle. Though 9/16 at the saddle could work if you like such a wide spacing, I guess.
Do what I did - find a soprano you like the feel of and copy its spacing.
These users thanked the author profchris for the post: wbergman (Sun Mar 06, 2016 9:15 am)
PostPosted: Wed Mar 09, 2016 1:04 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Yep....9/16" is weird. I use a 3/8" spacing at the nut. Check these free plans for dimensions.... http://www.grellier.fr/plans/Soprano_uk ... ele_en.pdf
I shoot for 0.09" action at the 12th fret. Some like higher action though. I'm a light strummer so I like lower action
These users thanked the author Quine for the post: wbergman (Wed Mar 09, 2016 1:14 pm)
PostPosted: Wed Mar 09, 2016 4:10 pm
I was referring to measurement at the bridge. So, it's 14 mm plus a bit.
PostPosted: Thu Mar 10, 2016 4:36 am
Last Name: Reed
City: Stowmarket
State: Suffolk
Country: UK
I find that too wide for comfort. Like I said, worth finding a soprano you like the feel of and measuring its string spacing.
These users thanked the author profchris for the post: wbergman (Thu Mar 10, 2016 7:00 am)
PostPosted: Thu Mar 17, 2016 12:42 pm
3/8 nut, 9/16 bridge, 2 - 2 1/2mm@12th. Pretty standard.
Although It's usually referenced as 1&3/8" nut (with strings about 3mm in fron the edges) and 1&3/4" string spacing at bridge.
These users thanked the author Pmaj7 for the post: wbergman (Thu Mar 17, 2016 4:04 pm)
