It is currently Sat Aug 02, 2025 12:02 am
 Post subject: Aluminum bridge
PostPosted: Wed Mar 09, 2016 2:17 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Sorry it's taking so long... I needed a new mill and some tooling, plus school was taking up most of my time, and work took up the rest (I wouldn't be able to do any of this without the work).
So here's the aluminum block squared up. I realize it's still oversize but I'll fix that in a bit...
here is the bridge compared to the aluminum block. I will then need to cut it to size.
The reason I got 3 vise on the block is because it's a bit too long, and so the piece would flex as the fly cutter passes through it, making the finish quality bad... The vise just keeps it from flexing.
Typhoon Guitars
 Post subject: Re: Aluminum bridge
PostPosted: Wed Mar 09, 2016 5:17 pm
Interesting, whats the purpose of it?
PostPosted: Wed Mar 09, 2016 5:20 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
No purpose... just to see if I can do it.
Typhoon Guitars
PostPosted: Wed Mar 09, 2016 5:49 pm
OK, it makes sense then. Keep us posted.
PostPosted: Wed Mar 09, 2016 7:43 pm
First name: D
Last Name: S
Glad to hear you are back in school Tai!
Best wishes,
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Mar 09, 2016 8:10 pm
Last Name: Beaver
City: Lake Forest
How would you attach it to the top? Epoxy?
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 09, 2016 8:20 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't... I don't intend to put this bridge into service. I don't think there's any sure fire way to attach aluminum to wood at all. Maybe small bolts backed with steel bridge plates...
Typhoon Guitars
PostPosted: Wed Mar 09, 2016 8:33 pm
Last Name: Beaver
City: Lake Forest
I See. Just a practice project then.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 09, 2016 10:11 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Tai Fu wrote:
I don't think there's any sure fire way to attach aluminum to wood at all..
Boeing has this figured out. FPL etch is a good first step. Phosphoric acid anodizing provides a reliable bond for epoxy on aluminum, and epoxies bond well to wood. Doing this in a small shop would be difficult, and then you're left with a bridge that weighs 3 times as much as cocobolo. As a machining exercise, it's excellent (or at least, very difficult).
PostPosted: Wed Mar 09, 2016 10:23 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Why not try something like Burtons circle cutter or parts for the really cool kerfing machine or some other jig? When I experiment with making things I like it to have purpose.
These users thanked the author Bri for the post: jack (Thu Mar 10, 2016 9:37 am)
PostPosted: Thu Mar 10, 2016 12:17 pm
First name: Stuart
Last Name: Gort
Sure there is....a phosphoric or boric acid anodize followed quickly by a BMS-1011 primer (baked on) would give the bond strength, using epoxy, about 3000 psi peel strength.
Lol....any shear failure would take the wood with it.
You could also treat the aluminum with gold alodine and then bond directly to that...and, although it wouldn't be nearly as strong as the BMS primer...it would STILL be stronger than the wood....and you could do that in your shop.
StuMusic
PostPosted: Thu Mar 10, 2016 2:51 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
Hysol 0151 has a temperature range of -65° to 160°. So, the bridge could be pulled off without damaging the underlying wood.
On etched aluminum it has a sheer strength of 3000 psi, when post-cured at 180°. When cured at room temperature for the full 72 hours, the sheer strength is 1850 psi, which is still plenty strong for luthery.
Another benefit is it's optically clear.
PostPosted: Thu Mar 10, 2016 5:10 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Rivets :)
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
These users thanked the author Shaw for the post: jack (Thu Mar 10, 2016 6:59 pm)
PostPosted: Thu Mar 10, 2016 5:16 pm
Last Name: Shaw
City: Philadelphia
State: PA
As someone who likes tinkering with my Taig mini lathe experimentation like this can really come in handy in the future especially for repair jobs. It can give you the skills you need for a practical future project.
