It is currently Tue Aug 05, 2025 4:34 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bandsaw vs Tablesaw
PostPosted: Thu Mar 10, 2016 11:40 pm
First name: Mark
City: Concord
The only negative I can say about a larger band saw is the need for a smaller one to do tight scrolling. Changing blades is a pain.
PostPosted: Fri Mar 11, 2016 1:23 am
We have two little 10" saws for that, a Ryobi and a ROK. The ROK is actually a really good but small saw.
The Laguna gets a curve blade only when we get planks to cut neck blanks from...
PostPosted: Fri Mar 11, 2016 3:37 am
First name: Patch
Last Name: Rubin
To me they are two different tools. You can get there with both but to get where you are trying to go with a table saw using a band saw you are going to have to put in some extra work after you have made your cuts. I have the Bosch saw you put a photo up of and I love it. Was a trim carpenter and cabinet maker for years and used many different job site table saws and in my opinion the Bosch is by far the best. If you already have a band saw, even if it's not as great as you'd like I'd still go with a table saw and upgrade the band saw later. I use it constantly while making parts for guitars and especially making jigs to make the guitars. If floor space is a problem the Bosch can fold up and be rolled away or be built into a work table. Once you have a table saw to work with you'll be amazed that you've gotten so far with out one. Plus if you've just bought a house there are probably plenty of projects where a table saw will be really useful too.
http://www.wideskyguitars.com
https://www.instagram.com/wide_sky_guitars/
Users browsing this forum: stumblin and 13 guests
